Thanks, are they the ones that come with the cheapest Final E model, with that being the best value way to get them? They look very similar to Sony tips, I should probably try those on BA8 too, I have loads from MH750/755s, MH1 etc, plus clones from Chi-Fi. The Problem I find with some Chi-Fi brands like Trn is the angle of the nozzles often don't fit my ears no matter what size I use and I end up resorting to foams to get a seal.Try Final Audio E Black Tips, they tame the treble quite well.
TRN impressions thread
Yeah the Final E black tips sell about $15 USD for a set on online portals like Amazon. But if you buy IEMs like the Final E500 or Kinera Tyr (costing $20), they come with Final E black tips. Think of it as getting the IEM for 5 bucks more LOL.
Do note the Final E white tips don't tame treble as much, it is the black ones that do.
Mr.HiAudio
Member of the Trade: RIOBuds
Ok, and here are the FRs:
Top to bottom, MT4/10mm DD only FR, 6mm DD FR without attenuation, 6mm DD FR with 10ohm attenuation. Listened to the 6mm alone and it's pretty loud and behaves like a full frequency driver. Very interesting.
![MT4.jpg MT4.jpg](https://cdn.head-fi.org/a/11995076.jpg)
red line - only 10mm driver
saldsald
- Dec 9, 2016
That's weird. Let me measure again later.
Don't know if you guys saw this, but the TRN TA3 is now available on their AE store, I got a notification from a Discord server I'm on about it!
It really looks like it uses the same structure as the MT4 + 1 knowles BA and a modular cable, and of course it looks more premium.
I bought the MT4 mostly because due to it being chip and coming with their T tips, I guess depending on how I like it, I might get the TA3
Quoting myself there, but I juste received the MT4, and haven't given them a good listen yet, but I can confirm that they only come with one set of medium T tips (and me having big ol' ear canals, they're way too small for me :/)I bought the MT4 mostly because due to it being chip and coming with their T tips, I guess depending on how I like it, I might get the TA3
Guess I'll have to either order one large set later, or wait to see if the TA3 comes with all the sizes.
saldsald
- Dec 9, 2016
Your probably should check the soldering again or maybe the back vent filter of the 10mm DD coz I cannot replicate your measurement. I measured the 10mm DD only FR again and it's identical to my previous measurement. It doesn't make sense the 6mm DD can have a FR loud enough to cross the 10mm DD resulting in a FR like the stock form I think.That's weird. Let me measure again later.
![1677463873752.png 1677463873752.png](https://cdn.head-fi.org/a/11997476.png)
Carpet
Be aware the T Tips are on the small size, a bit like Spring Tips. So if you take XL Spring Tips L CP100 or L KBEAR 07, these aren't gonna get a good seal.
![Triport Sad :triportsad: :triportsad:](https://cdn.head-fi.org/e/headfi/triportsad.gif)
Mr.HiAudio
dear, im so sorry, my mistakes.That's weird. Let me measure again later
All the same, at the weekend I took apart my headphones and realized that my big speaker just broke after burn-in(maybe) - that's why there was no bass.
After the test, I realized that the small speaker sounds very quiet and adds almost nothing on its own.
saldsald
- Dec 9, 2016
Actually it looks to me that the 10mm DD is misplaced or there is a gap between the DD and the front cavity resulting in a bass leak. You could try adding some glue (best use UV glue) around the 10mm DD cavity of the shell to seal it up. I think the 6mm DD only adds note weight it's dim but I think it audiable. But anyway the MT4 is not a detail monster considering the configuration and its price point.dear, im so sorry, my mistakes.
saldsald
- Dec 9, 2016
The TA3 is for sale on TB priced at 398
(maybe it's just a place holder)
Edit: it's also on AE now
https://www.aliexpress.com/item/100...vid=202302261945053413143408869580011641282_1
and here's the graph:
vs the MT4
hmmmmm....
![O1CN01kXJC6I1Xf9D21u6oc_!!2212463682950.jpg](https://img.alicdn.com/imgextra/i3/2212463682950/O1CN01kXJC6I1Xf9D21u6oc_!!2212463682950.jpg)
![O1CN016nHF5o1Xf9D0Urqa9_!!2212463682950.jpg](https://img.alicdn.com/imgextra/i2/2212463682950/O1CN016nHF5o1Xf9D0Urqa9_!!2212463682950.jpg)
![1677469060656.png 1677469060656.png](https://cdn.head-fi.org/a/11997533.png)
vs the MT4
![1677469101376.png 1677469101376.png](https://cdn.head-fi.org/a/11997535.png)
hmmmmm....
Mr.HiAudio
i replaced a DD to 8mm titan driverActually it looks to me that the 10mm DD is misplaced or there is a gap between the DD and the front cavity resulting in a bass leak. You could try adding some glue (best use UV glue) around the 10mm DD cavity of the shell to seal it up. I think the 6mm DD only adds note weight it's dim but I think it audiable. But anyway the MT4 is not a detail monster considering the configuration and its price point.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
https://sl.aliexpress.ru/p?key=PSFswU1
Super DD, very wonderful!
Replaced in fake Light Harmonic Mera this driver and now sound super!
Ps MT4 ordered too
yeah that had me raising an eyebrow, too.The TA3 is for sale on TB priced at 398![]()
https://www.aliexpress.com/item/1005005245225410.html?spm=a2g0o.productlist.main.9.66a9fd0aedxqiH&algo_pvid=d15fb1a5-1538-4be1-afdf-3e94c818a6ce&aem_p4p_detail=202302261945053413143408869580011641282&algo_exp_id=d15fb1a5-1538-4be1-afdf-3e94c818a6ce-4&pdp_ext_f={"sku_id":"12000032344079289"}&pdp_npi=3@dis!HKD!758.78!455.25!!!!!@211bea7b16774695051516439d06c7!12000032344079289!sea!HK!2510364788&curPageLogUid=6vsxQHFWeyYq&ad_pvid=202302261945053413143408869580011641282_1&ad_pvid=202302261945053413143408869580011641282_1
vs the MT4
hmmmmm....
My guess is that whereas the TA3 has electronic crossover and passive dampening, the MT4 only has the later.
So the signatures are quite similar, but the TA3 is potentially more refined.
saldsald
- Dec 9, 2016
Hmmmmm, that 'electronic crossover' worths about one RMB and it exists in the MT4 actually. The TA3 I bet has one more resistor and one more capacitor so maybe that's not the real retail price of the TA3 I don't know or it has a better pair of DD...hmmm..yeah that had me raising an eyebrow, too.
well the TA3 also comes with a modular cable and a much more complex faceplate, so I guess that also could be some of the reasons.Hmmmmm, that 'electronic crossover' worths about one RMB and it exists in the MT4 actually. The TA3 I bet has one more resistor and one more capacitor so maybe that's not the real retail price of the TA3 I don't know or it has a better pair of DD...hmmm..
Good eye about the MT4, I didn't catch that!
Total: 7 (members: 0, guests: 7)
