TRN impressions thread
Mar 21, 2023 at 2:26 PM Post #3,751 of 3,805
The BA15 is 79.9 after discount. Is it worth a shot? I just did the math this price is about the price of getting the 30 BAs on Taobao.
Very very great, take TRN T tips and they are awesome for classical
I have the TA3 it's a brilliant and balanced ta2 very good finishing
A controlled bass, great clear vocal, large scene, sensation of aeration
10khz peak is present fatiguing but not harsh
Mar 21, 2023 at 3:24 PM Post #3,752 of 3,805
Rosefinch graph courtesy of ianfann.squig.link
Mar 21, 2023 at 4:02 PM Post #3,754 of 3,805
Looks pretty warm, but planar bass doesn't usually seem as prone to bleed. Interesting to see how that energy before the resonant peak sounds in real life. Looks a little like MT3 which I didn't like. :thinking:
5k and rising tuning for old school V vibes (* ̄∇ ̄)ノ
Idk why they insist on that
Mar 23, 2023 at 7:45 PM Post #3,755 of 3,805
Rosefinch recepted
For those who know the Kirin sound... It seems similar... Very scintillating
I will see tomorrow but too much for at first impression
Mar 24, 2023 at 12:17 AM Post #3,756 of 3,805
Still warm but planar and BA mid bass have great control as you said, they arent bleed to mid area at all, snappy fast mid bass without bloom, smear like most DD bass implementation. So little bit warm tuning for planar/BA mid bass is acceptable for me, but gain the sub bass, they dont have air moving feeling like DD bass sub bass.
Mar 25, 2023 at 7:22 PM Post #3,757 of 3,805
So
I finish my french review of ta3 it's a good balanced to neutral iem, with extreme high frequency peak
Very polyvalent, natural, good detail retrieval, great scene
Better technically and better clarity than tin Gigi t3 plus
But technically I prefer the more engaging ST5, more funny more wow effect ( but not for jazz, dub )
I begin to work on rosefinch. For those who like TRN KIRIN you'll like. More brilliant, bass is more balanced.
I can't use with default tips, the great planar extension make the brilliance peak habit very uncomfortable for me very fatiguing. I must to use foam tips to tame this peak. It's less efficient than Kirin but help a lot
Build is great, cable very great !
Apr 1, 2023 at 4:27 AM Post #3,758 of 3,805
Got my Rosefinches in and yeah, they're killer. There's nothing in the $20-70 range I'd recommend more. The value is absolute absurd and while they lack a little polish, they have personality and planar texture that I was hoping, with a lovely spacious soundstage and a relatively bright, energetic vibe with very well controlled, neutral bass.
The cable is lovely, it's like a lighter weight version of the dioko, but with an interchangeable plug. only the 3.5mm comes, but a 4.4 is $10, and you can also get a USB-C and lightning dac attachment. Included T tips are obviously a value adder too.
The treble can be a little hot at times, but I like bright sound and it's not sibilant. high instruments like upper piano keys, trumpets, and cymbals have pop and shimmer, and the mids are nice and forward and in-line with the bass and it has all that planar texture and speed. Pianos in particular sound incredible.
And they round that all out with a nice, spacious soundstage and decent imaging. Detail is pretty good, and they don't struggle with busy music.
They also really like tubes.
Apr 10, 2023 at 5:44 PM Post #3,759 of 3,805
I don't like at all Rosefinch
My review ( you have Auto translation )
For those who like big big clarity you can like
Apr 28, 2023 at 12:13 PM Post #3,760 of 3,805
Upon review, The TRN Rosefinch with the 4.4mm plug are very good. Better than the SE 3.5mm plug. It doesn't do well with lower volume levels I use in the cubicle. When the volume is up a little, it has a decent, if warm soundstage. I can tell where the instruments are if the master recording is good.
May 21, 2023 at 7:04 AM Post #3,761 of 3,805
I have been revisiting the TA-2. Via my Hidizs AP80 Pro X with the 2.5mm balanced cable from the ST5, I was surprised at the quality sound I was getting. Well balanced across the frequency range with excellent detail, layering and a lovely soundstage. This piece sounds wonderful, superb sub bass on the drum with lots of weight.
May 31, 2023 at 11:34 AM Post #3,762 of 3,805
Hi TRN Fans, How true do you think this image is....? If its correct then the TRN stock cable that comes with EMA is incorrect. I checked with multimeter. Here is the thread which i found the photo, and its all in chinese. I have no idea how the OP of this thread determined the polarity of EMA drivers.
https://28review.com/forum.php?mod=viewthread&tid=79
Jun 12, 2023 at 11:17 AM Post #3,763 of 3,805
