I am still trying to measure the FR because I went into problems with my DAPs don't want to play the testing sound via bluetooth when using ARTA/REW...
I think it is a faster version of the TA1 MAX with a faster bass in general. The bass is equally strong and punchy as the MAX and the ST5 so I guess it's the same berry DD again, which is a good thing. Sound overall is smooth with good extensions at both ends and very good balance but the MAX has a slightly sharper sound and better extreme treble extension since it is wired and perhaps because it has a metal shell. The stage is pretty impressive with correct placement of the frequencies and I think this is one of the highlights of the T350. Detail retrival is very good for a TWS IEM in this price range but the overall detail is probably limited by bluetooth mostly at the extreme treble end. Connectivity and the passive isolation are excellent and I will check its connectivtity stability in the crowd later.
I think it will open-up more as I am hearing more treble detail so will update my impressions later.
I would also like to say that the sound quality actually depends on the BT (or even DAC?/pre BT processing) quality of the source. I just tried with the Shanling M8, Hiby RS6 and my Samsung phone and the M8 sounded inferior and the RS6 sounded best. Perhaps if you have a Shanling device, just avoid using it with any TWS IEMs. Playing through the RS6 I actually heard similar hifi quality as wired IEMs at least in this price range.
I further tested with the Sony ZX507 and the sound quality was very good, even better than the RS6. I actually find the SQ with the Sony better than the TA1 MAX here or maybe comparable to the ST5. The notes are rounder but more airy and very punchy. I have hard time to tell this is a TWS IEM here already. The only complain from me is that on some tracks I hear hints of sibilance but it's very acceptable.
Also I should have posted picture of the IEM.
vs the ST5 and XuanWu.
The shell is rather different, almost like a typical KZ shell actually with very good seal and comfort.
**Updated my impressions.
