maverickronin
- Apr 5, 2010
It really depends on what you are listening too. If you are listening to normal stereo mixes and don't have a software or hardware crossfeed/HRTF processor then you'll want a 'phone with a HRTF built into its FR curve like the LCD-2. That way it will sound more like it should on the speakers it was probably mixed for. If you use a processor or are listening to binaural recordings or something similar which is taking care of the HRTF, then you'd likely want something with a flatter FR like the HE-6.
