Womaz
Well the Silver Widow 22 isn't your usual silver cable as it is mixed with gold which has the effect of smoothing the treble and boosting bass a tad.
Thanks for the clarification....so as usual I could end up over budget
Thanks for the clarification....so as usual I could end up over budgetI thought setting aside £600 was extravagant
(I hope Frank doesn't mind me doing a little pitch here to move it)
http://www.head-fi.org/t/830398/aus-toxic-cables-silver-widow-cable-24-westone-pins
No waiting time on this one.![]()
Here are 2 new plugs to the Toxic Cables range
Our new slimline 2.5mm TRRS and
4.4mm TRRRS
With our new screw collars for the ultimate strain relief
Here are 2 new plugs to the Toxic Cables rangeOur new slimline 2.5mm TRRS and4.4mm TRRRS
If it makes you feel better when you add the cost of my Silver Widow 22 for my Ether Flows, Hydra 22/18 for my Noble K10s and Hydra 22 for my Sony Z1R I have spent probably not far off £2k on headphone cables![]()
Well..i spend a small fortune on my balanced 8wire sw22..but by god it was so worth it on my code-x and the blue circle audio amp i have..very balanced cable with best of copper and silver but without the negatives.. if you have a detaily rig..go for sw22...its powerful but with just the right extension in the highs..
If you can: go balanced...it will blow your mind on a rig that excels in detail. (Check my review about the sw22 under this post)
Good luck with your choice...
Damn..now i think of it..i need a new cable myself for my custom art pro330 v2 ( yep, a very carefully budget re-entry into the iem world after hating them for years)...and i need a balanced cable with 2.5 trrs balanced connector
so FRANK!!! Help...![]()
And i hope you all had a good christmas![]()
My Sw24 came with the new Trrs 2.5mm termination and new colar. Looks fantastic. Thank again Franck for your job. I don't regret my purchase.
Nice finishing touches to an already awesome cable. Great job, Frank!
Oh and, in case I'll miss it later.. Happy New Year, everyone!![]()
