Toxic Cables
Member of the Trade: Toxic Cables
- Dec 17, 2011
@Toxic Cables How are you feeling mate?
Much better mate, thank you.
Going back to work tomorrow, although still do some from home now.
Gone completely mad and ordered Silver Widow 22 cable and also black AK380 + Amp.
As I said, I've gone mad.
You sound just perfectly rational and sane to me
Any suggestions for a balanced to match with k10's? Will be purchasing onkyo dpx1 soon and want to already have a balanced cable lined up.
I have tried Silver Widow 22, Hydra 18 IEM and have a Hydra 22 on the way. For traveling I personally would go for Hydra 22 as it should have the same audio qualities as the Hydra 18 IEM (almost the same thickness of metal per channel) but it should have the flexibility of the Silver Widow 22 (I find the Hydra 18 IEM a bit too springy for portable use).
I found the Hydra picked out the treble and soundstage better but didn't effect the bass much which considering the K10s already lifted bass is a perfect combination. Hope that helps.
I'm a little worried that Frank is struggling- I ordered a cable on the 4th of August, and so far, no sign of it. Without wishing to read too much into what be a freak incident, is he OK?
