Kiats
Just a short note on the virus for LCD that Frank sent across: for those of you who missed the organic bass which was obscured when Audeze increased treble in the LCD 3, I have good news - the virus will bring back the organic bass while preserving the transparency and treble extension. wonderful!
sidrpm
Member of the Trade: Wired For Sound
- Apr 8, 2013
Just a short note on the virus for LCD that Frank sent across: for those of you who missed the organic bass which was obscured when Audeze increased treble in the LCD 3, I have good news - the virus will bring back the organic bass while preserving the transparency and treble extension.wonderful!
Can't wait to try it!
MrLou
- Sep 18, 2013
received my IEM cable and it was done very nicely. I do have one question, it is not marked for positive or negative. The way the cable was bent the L and R are facing inward when installed.
setamp
- Jun 27, 2009
I am curious as to how the virus compares to the SW. Are the mids and highs as silky smooth?
MrLou
- Sep 18, 2013
Double post
Toxic Cables
Member of the Trade: Toxic Cables
- Dec 17, 2011
All my cables will have markings, please look at the actual connector and depending on the cable you have, the right will be red and the left Black/Blue, or it will have the letters L and R on the connectors.
Kiats
Yes, they are, setamp. The mids will be slightly warmer and fuller. The thing about the Virus is that you have the best of both worlds - the BW and the SW, maintaining a balance between the two while sounding very coherent. Not something you can always say about hybrid cables.
Kiats
MrLou
- Sep 18, 2013
the connectors read L and R but nothing showing positive or negative so I am not out of phase. Or I am just not seeing the marking?All my cables will have markings, please look at the actual connector and depending on the cable you have, the right will be red and the left Black/Blue, or it will have the letters L and R on the connectors.
Toxic Cables
- Dec 17, 2011
The wire would be molded to show which way up it should be to go around your ears.
Which cable do you have and for what IEM.
Just re read your original post. If you have the Westone connectors with the metal housing, then the L and R should face inwards, just how the wire has been molded for them to do so.
MrLou
- Sep 18, 2013
Thanks!The wire would be molded to show which way up it should be to go around your ears.
lin0003
- Jan 4, 2013
I just got my SP and man, I'm lovin it already. I thought it wouldn't be a huge upgrade over the Blue Dragon but man, was I wrong. It sounds much clearer and has a brighter sound sig. The bass is awesome with slightly less impact, but much better detail.
claud W
on what headphones?
Toxic Cables
- Dec 17, 2011
on what headphones?
It was for the Hifiman, not HD600
I am sure you will like it with the HD600 as it pairs very well with the HD650, if you don't, we can work something out.
lin0003
- Jan 4, 2013
HE-500.on what headphones?
Total: 9 (members: 0, guests: 9)
