Topping DX7 - DAC and balanced headphone amplifier
post-14876757
Post #391 of 451
Reebonz
Very interested to streamline my desktop separate DAC and amp setup to just the DX7 Pro.
Quite rare to see 2.5mm output in a high end desktop dac/amp which is great for my IEM and $600 is pretty reasonable considering the spec and features.
@maxxevv Did you tried testing it with a sensitive iem and is there any hiss to be heard? Is the DX7 Pro capable of MQA decoding and rendering?
post-14876814
Post #392 of 451
maxxevv
1 Degree North
1 Degree North
Nope. I didn't but Topping does have experience and have demonstrated their expertise with portable, sensitive head gear in their portable amps from the NX series. So I have little reason to think they will botch that portion of things.
Do note that the US$600 price range for the DX7 Pro is just an estimated figure based on the DX7S pricing, its stil some 3 months out from release, so whether they stick close to that is still to be seen.
post-14877283
Post #393 of 451
Arniesb
Wouldnt buy Topping again, Socket for power cable in my unit wobble and i only taken it out few times.
post-14901107
Post #394 of 451
PurpleAngel
California
California
I just ordered the Topping DX7s from Massdrop, want to compare it's balanced output audio quality to the unbalanced output on my Audio-GD NFB-11.28.
post-14915157
Post #396 of 451
Gauss1777
Anyone pairing this with the Sennheiser HDV 820? I know it's a cheap DAC but I was wondering if cheap is just "cheap" and more likely a SMART buy as the product just delivers for the price. If you were to get a separate Amp (Smart buy) to pair with the Topping DX7s which one would it be?
post-14915586
Post #397 of 451
maxxevv
1 Degree North
1 Degree North
JDS Atom or Massdrop THX 789.
There really isn't anything at that price bracket that competes in terms of output measurements.
post-14934383
Post #398 of 451
Toshu
Anthem, Arizona
Anthem, Arizona
Anyone use a USB Silencer like the iFi with the Topping DX7s?? if so what are your thoughts.....snakeoil or real??
https://ifi-audio.com/products/isilencer3-0/
Also, anyone try using a Linear power supply like the iFi iPower ??? I have my Topping connected via USB to an Android TV box. It was recommended that I buy one in order to address Jitter. Does the Topping circuitry address jitter internally??
https://ifi-audio.com/products/ipower/
post-15002091
Post #399 of 451
Toshu
Anthem, Arizona
Anthem, Arizona
Auto on and off...
I have my DX7S working such that it turns On automatically when the attached USB source is turned on,but it won't turn Off when the USB source is turned off.
Any suggestions on getting the auto off to work??
post-15026316
Post #400 of 451
PurpleAngel
California
California
Topping lists the DX7s 6.35mm (1/4") headphone jack as having an output impedance of under 10-Ohms, any know a more exact reading of the output impedance?
post-15026419
Post #401 of 451
jsmiller58
Isolated
Isolated
Don’t have anything more exact other than the discussion on ASR is that the output impedance is 10ohms...
Edit: looks like 10 ohms SE, 20 ohms balanced... yikes. I have the DX7S, but only use it as a DAC to drive my 789, so I really don’t have experience with the sonic qualities out of the DX7S headphone jacks...
post-15026539
Post #402 of 451
Voxata
The onboard DX7s amp isn't that bad. It works great in a pinch and sounds fine - though the 789 sound is much preferred in my opinion.
Reactions: Baten
post-15026873
Post #403 of 451
PurpleAngel
California
California
So far I've only really used the balanced headphone jacks, on the DX7s to drive my HD58X headphones :)
post-15045749
Post #404 of 451
lagadu
PT/DK
PT/DK
Auto on and off...
What's your USB source? I found that with mine (an old macbook) the DX7S immediately shows "--- kHz" input when I close it but only actually turns off after a few minutes after that.
post-15045999
Post #405 of 451
Toshu
Anthem, Arizona
Anthem, Arizona
My USB source is an Android TV box.
