Any updates on possible release dates for the upgraded Topping DX7pro??
I have mailed Topping about it. No answer yet.
Well, well, nice. Would buy one .I have mailed Topping about it and the DX7S will be available at the end of February. Price will be no higher than 500 dollars.
ThanksHey guys, I think I have a solution for anyone experiencing an issue with their DX7 preventing their pc or monitor from entering sleep mode. Basically the device installs a usb audio driver and a human interface device driver and it is the hid device driver implementation that is causing the issue. If you open up device manager and unplug and then replug the DX7 usb cable you can figure out which hid device entry is associated with the DX7. Then just simply disable the corresponding hid device and the problem should be solved without breaking or altering the normal function off the unit.
I just finished my measurements of the DAC portion of the DX7 comparing it to D30. There is no question the DX7 is a measurably superior DAC. See: https://www.audiosciencereview.com/...phone-amplifier-review-and-measurements.2286/Hi, I am a new member in Head-Fi. I have read all the post here bout the Topping D30 and the DX7. I actually ordered a D30, but wanted to pick some of your brains. I would like to know what you would recommend between the D30 and the DX7.
Here is some data from that:
As you see it is much better in low level noise/distortion. It is now my recommended DAC, replacing the D30.
