Technopiper
I couldn't get DoP64 over SPDIF, but I only gave it one shot and switched to usb. I get DSD via DoP alright, no problem there. I see no point in using native as there isn't any DSD512 anyway.You understand it only allows DoP64 over SPDIF? For SPDIF that usually means using WASAPI, Some software can be awkward with DoP over wasapi I noticed, but it should be possible, was this HQPlayer you tried?
DoP is DSD in a PCM container, it can work up to 256 DSD since D50 supports 705.6kHz.
As for DSD to PCM conversion, I agree there is little difference, and personally I dont like it because it seems to add very subtle distortion to the sound, but a pleasant kind and it might bring out some other details better than PCM. The main point is how its handled differently upstream, it has been said that Sabres DACs like D50 will not get the full theoretical benefits of DSD conversion that other DACs will.
I highly recommend trying real DSD recordings to hear what it can sound like. a good example is Hoff Ensemble - Quiet Winter Night.
Further comparison between DSD and CD: I listened to Mozart's violin sonata no. 28 by Podger/Cooper. I use foobar's "random play" between CD and DSD versions and think I can tell which is which. The DSD version sounds more "transparent". Now I'm talking like an audiophile.
