Erik Garci
- Jan 13, 2004
It can. It sounds just like the speaker system that was measured. The Realiser A16 will include Atmos.Can it do 5.1 or Atmos convincingly?
You should audition the Smyth. Not easy to do, but if you ever get a chance, take it. It might change your mind on a few things.
Here is my latest setup:
Stereo source ==> miniDSP 2x4 (Linkwitz-like crossfeed) ==> Realiser A8 (crosstalk-free PRIR) ==> headphones
Basically I hear stereo audio coming from the front but with headphone crossfeed instead of speaker crosstalk.
I think it sounds better. The A8 mix block merely changes ILD for all frequencies equally. Certain types of crossfeed make changes to both ILD and ITD that vary depending on frequency, which sounds more natural, while avoiding the comb-filtering artifacts that speaker crosstalk would typically introduce.Is it better than your crosstalk free PRIR and the A8 mixblock to add crossfeed?
The A8 lets you adjust the bass, treble and volume levels between -12dB and +12dB per channel. I don't know if the A16 will offer more EQ controls.Can you adjust the level and EQ of each channel?
I've just read from an A8 user that he uses his unit with a special PRIR (in which the left microphone only recorded the left channel sweep, because he muted the mic for the right ear when the A8 played the sweep tones for the left channel, and the right microphone only recorded the right channel sweep, because he muted the mic for the left ear when it played the sweep tones for the right channel) and a mini dsp to have more control over the way the crossfeed is done.
But I guess that somehow detracts the personalization.
You mentioned that you can add a playback mode in which the signals assigned to left speaker are not played back at the right headphone driver and vice versa.
But that equals to total crosstalk cancellation.
As far as I understood, Dr. Choueiri uses an algorithm that achieves with headphones a similar effect that one would achieve with his crosstalk "cancellation" (reduction) applied to speakers.
I was wondering if you could add more control over the way the mix is done in the A16.
The idea is to have the freedom to control the "dosage" of "virtual crosstalk" without having to resort to any external processing.
Cheers.
Another approach is to make a PRIR of the crossfeed itself by measuring headphones instead of speakers, and then load the crossfeed PRIR on user B which feeds the crosstalk-free PRIR on user A. That way you can eliminate the separate crossfeed device.But I do not know if it would really be in their interest to develop this functionality if the main purpose of the A16 is to emulate Dolby, DTS and Auro systems...
Stereo source ==> Realiser user B (crossfeed PRIR without head-tracking) ==> Realiser user A (crosstalk-free PRIR with head-tracking) ==> headphones
I just cant crossfeed. It ruins the sound signature for me Ive not found one that doesnt.
