gimmeheadroom
LOL 2 channel... I am not into home theatre so 2 channel is all there is for me
Thanks guys
Thanks guys
Preference only varies in the second category, all dacs in the first category sound the same. Knowing Parasound they probably also fall into the first category. Its funny how you degrade the ESS chip based on costs, because very few implementations even come close to a reference implemenation using that "budget" chip. A good implementation of a "budget" chip beats any bad implementation of a higher end chip. Unless you like the colouring added of courseThe headphones on the market are typically coloured with a lot of sound signature from brand to brand.
Dacs are all over the map as well. The preference of each person varies from brand to brand.
Transparency and resolution plays a major role in the system as well the DAC itself.
Just recently using the built in DAC in my Parasound P6 preamp is quite refined without digititus even using the cheap was Sabre chip. I’m rather shocked to be honest. For organic realism the space tech local built DAC is amazing without mushy vacuum tube bloom.
People must test to hear what they like.
I'm curious if you know the design principes employed by the creators of your DACs? I've done some comparison and only the ones where the creator is known for having a sound signature sound different. All DACs I tried that were made by companies with the goal to represent the information present as accurately as possible sound the same. To be fair I only compared the Benchmark, RME, Topping and SMSL to Schiit Multibit, some Muse 4x1543 NOS cheapo dac and a Vincent one with a tube stage. Maybe my system is not transparent enough because I'm only running a $2000 amplifier with $3500 speakers.
I presume you ABX tested all that right? I know I did. Saved me a lot of money. Tried some crazy power conditioner for my amplifier, turned out it was designed by a competent designer and had no effect. So that was great.
WRT R2R: If you are going by measurements then achieving DS-like distortion figures is very difficult with R2R by nature , still the majority of recent R2R DAC measurements show very low distortion levels that are not considered to be audible. They will look ''bad'' if directly compared to DS.Stereo speakers.
Anyway in my 2 cents is that there are two kind of DACs:
The most analogue sounding DACs can be found in the second category because they create errors in the reproduction that are similar to analogue systems (vinyl, tape). They however do not reproduce what was recorded.
- DACs that are acoustically transparent, they just play exactly what you feed them and all of the DACs in this category will sound exactly the same (when level matched) because all the distortion and other issues are below our hearing threshold. Think RME, Benchmark, Matrix Audio, SMSL and Topping.
- DACs where the designers goal wasn't to provide a 1:1 copy of what is being fed to it, notable examples here are all DACs with a tube stage or R2R multibit DACs. But also plenty of DS DACs. Examples of these kinds can be found at Schiit multibits, Audio-GD or PS Audio for example.
I think most R2R DAC designers do aim to make the best measuring and most transparent DAC they can, in fact some recent R2R DACs have some of the lowest distortion ever seen with R2R.
Exceptions Ive seen are AGD R2R11 which was pretty bad (but that's really AGD DACs in general, even DS) and Airist DAC wasnt the best but you will notice both are some cheapest R2R DACs available,
due to precision parts needed for R2R you can never have low price and high performance like DS.
The point I was making is that most of the R2R DACs should be audibly transparent according to the measurements. You would be paying extra for nothing, rather some audible distortion/ pleasant colouration.R2R is mainly a fun challenge for the designer to see if they can beat an DS dac. For the end user it is just a waste of money because DS outperforms it by quite a large margin. The only thing an end user stands to gain is lower performance. It has no place in transparent audio reproduction. If your hobby is just playing with suboptimal performing gear to get a sound you like instead of the sound that is in the media content R2R can be fun just like tubes and other non-ttransparent gear.
Yes, I agree. But a lot of R2R DACs aren't transparent. And if they are they are more expensive than DS DACs, so there is no point in buying them.The point I was making is that most of the R2R DACs should be audibly transparent according to the measurements. You would be paying extra for nothing, rather some audible distortion/ pleasant colouration.
If people can actually hear differences then it's the measurements that are sub-optimal.
True, but what proof do you have these 'transparent' DACs are actually transparent?Yes, I agree. But a lot of R2R DACs aren't transparent. And if they are they are more expensive than DS DACs, so there is no point in buying them.
ABX tests already confirmed no difference can be heard. Measurements already indicate that any difference is far outside hearing range. We are talking about being able to hear a pin drop next to a 747 taking off...if these people have such great hearing they are mutants and of interest to science.True, but what proof do you have these 'transparent' DACs are actually transparent?
Too many to ignore claim they can hear differences, we need ABX tests to truly confirm it.
https://www.audiosciencereview.com/...-measurements-of-holo-audio-spring-dac.10047/Can you link me to R2R vs DS tests?
Im suggesting the difference lies outside the measurement, if inaudible distortions were the cause then the R2R would still be worse.
