AlanU
- Apr 20, 2015
The point I was making is that most of the R2R DACs should be audibly transparent according to the measurements. You would be paying extra for nothing, rather some audible distortion/ pleasant colouration.
If people can actually hear differences then it's the measurements that are sub-optimal and there might be more to the R2R vs DS argument.
The difficulty is the entire chain of components. Having an extremely expensive DAC with an average headphone amp and brand/type of headphone completely distorts any discussion of viewing DAC graphs/specs/measurements.
I've auditioned a tonne of headphones as my local shop has a massive selection. Regardless of what DAC, headphone amp I used there was always a strong sense of distinct sound signature/colouration on every headphone. A long time ago there was great hype in the Audioquest Nighthawk. I absolutely hated the sound signature but I assure you the dac and amplification was not the mediocre sort. My point is the collective effort in producing a certain "sound" is a blend of everything in the chain.
I'll admit I love solid state sound some days due to convenience. If I really want to sit down and enjoy the musical qualities of music I love analog vinyl or digital getting some added flesh with tube gear.
I've auditioned a fair share of high end 2 channel stereo gear (not headphones). Even the high end solid state gear provided overload of detail getting technical rather than kicking back and enjoy toe tapping rhythm. I was auditioning some SPA/Meditation type music with high resolution recordings of ocean waves. "So called" transparent digital dacs had intense hyper details. In my home using the same identical recording the Space tech tube dac with super rectifier setup has less detail but this envelope of holographic 3d sound that literally gives you the impression your feet are getting wet. The added harmonics, distortion provides a realistic experience I've yet to really experience with your average $25++++++ grand hifi stereo system.
The beauty of headphones is that your average high end gear will not require a car loan to achieve happiness.
I've mentioned this earlier but my Parasound Halo P6 preamp has an onboard DAC. ESS Sabre32 Reference DAC capable of DSD & 384kHz/32 bit PCM. I'm floored how such an inexpensive $2100 CDN preamp sounds refined, smooth and detailed. It has some meat on the bones which is rather surprising. It's easily comparable to so many other higher end solid state dacs costing 3x to quadruple. I've tested my Astron linear power supply feeding my Mytek Liberty dac (same dac as the older gen 1 Brooklyn) and the onboard DAC in my Parasound Halo is extremely apparent level beyond the Mytek. The musical quality without graph analysis is how I determine my purchase of gear. Yes it's my ears and my perception...... I do not justify my spending either. I honestly never even considered using the onboard dac at all.
Comparing any solid state dac with my Tube dac…….. I've yet to hear any 3d realism from solid state. My geeky audiofile friends (me included) are always pleasantly surprised how a tube dac can have qualities unheard from majority of all solid state dacs. There was a company called Blue Circle Audio and Gilbert was a boutique one stop shop. He had $6000+++ dac that had more AC line filtration than many high end Power amp manufacturers. His goal was musical bliss with solid state components and some with tube buffer conditioners line out. Many high end mainstream DAC solid state manufacturers only wish they can sound that good!!!
I think colouration is what provides musical enjoyment. For technical analysis having hyper detail with in your face transparency isn't my kind of system.What indicates real transparency?? When so many solid state dacs are engineered with a predetermined soundstage. They do not communicate with the sound engineer of the original recordings. Also different dacs put different placement of the instruments and vocals. Some will present the singer 3-5 feet forward or back in the "imaging". Real life in live events the instruments are not pin point located as the room bounces sound. These are all topics beyond comparing graphs. Not sure how a graph dictates the amount of air around the instruments. There is so much more than graph analysis.
