My first try was to replace the 2xop275 and 1xLM4562 for genuine parts, the sound is more detailed, but lacks body and sometimes is a bit sibilant, I didn't understood why it sounded like this and didn't like it. Later I went back to this option, just to be sure and got the same sound.
My second try was using 2xopa1652, this is musical and I like it, but it's polite, I want a bit of wow factor, not a polite sound.
My 3rd try was 2xLM4562 with opa275, with 4 nichicon finegold and the 2 stock elna, it's better than before, It's musical, has detail, has body, has bass and I enjoy this sound, but I would like to improve this even more.
Meanwhile with all those 3 options I tried a lot of caps, Panasonic and Nichicon.
I use 2 dip8 sockets to fast switch between a lot of caps combinations, without damaging the PCB pads.
In one of the dip8 sockets I made an optional bypass of the last stage transistors
Depending on the position I place the last 2 caps, I can bypass the transistors.
I'm ready for the next try, but not sure what opamps to try, AD8620A is a bit expensive just to try it, maybe another opamp.
I'm waiting for some TRRS 2.5 jacks to try the balanced output, before I proceed.
I have x3 opa1622 in my AK4497 DSD, configured as output buffers for both SE and balanced outputs, no output resistors or caps. Actually, no input caps either
Sounds great, including BA only IEMs, but requires a bit of work to retrofit it.
Next project will be based around INA1620
After reading this, I order one opa1622 from AliExpress (Hi IC store), I hope it's genuine, I wanted to try one for some time.
Were did you ordered yours from?
Do you know if it possible to buy only the PCB?
At some time, I've read you had 2xAD8066 in LPF are those worth buying for my next try ?
