Merlin-PT
- Jan 21, 2005
Did it work in the past with that charger and cable?
Is the blue light on?
Did not try, but someone here who removed the resistance in the output could maybe want to at least push up capacitance.How's the sound, doubling the capacitance there?
Little bit off topic at the moment, but just letting you know that Nichicon KW 220uf (at least the 16v rated ones) fit in the case (with some small adjustments)
KW are ok even on signal, comparable to FG ones, and is someone is interested in more than doubling capacitance there, it works.
What are you going to do with the resistors?Just received the zishan 4497 kindly sold by musicday.
Short impression: I tried with 1more quad driver (32ohm, 1 DD 3BA) good detail, punchy bass that I like a lot, pleasant mids, highs are a bit weak (not a lot, just a little bit compared with the sabre on my v20), soundstage is not wide.
In conclusion v20 vs zishan:
-Detail: draw
-Bass: zishan
-Mids: draw
-High: v20
-Soundstage: v20
-"Sound impact": zishan, the presentation Is more "on your face".
Now I want to start to improve my ZS, thanks for the suggestion about caps, I'll change them. Plus, I'll lower output resistors on SE out.
Now Can someone suggest me 2x opamp for LPF (instead of op275) and one opamp for gain (instead of lm4572) to achieve a sound more open, with more detail and wider soundstage (without losing those awesome bass freq.s)?
Thank you very much
