The Zishan dsd's corner
Jan 11, 2019 at 8:13 PM Post #1,486 of 3,717
@Draknodd
AFIK the USB interface is inside the stm32f745.
Probably they run code in the cpu to implement USB audio driver when we select the DAC mode in the interface, but I'm just guessing.
Did you already changed the LDOs and OSCs?
If not, try the LDOs first, to see what impact each mod has.
@Ivan TT
I'll try that, it was planned.
I was just looking at the opamps power supply and I measure these:
any opamp pin 4 to gnd = -8.86V
any opamp pin 8 to gnd = 9.26V
Do you know if it's ok to have this difference?
Jan 11, 2019 at 8:32 PM Post #1,487 of 3,717
It’s not a problem as long as the output is not pushed close to the rails voltage (high impedance headphones playing really loud), but even then most likely will result in onset of clipping kicking in on the negative swing a bit earlier.
I would not worry about it and have similar difference in mine.
Jan 11, 2019 at 11:17 PM Post #1,489 of 3,717
Jan 12, 2019 at 7:26 AM Post #1,490 of 3,717
With android it does not work at all because the usb receiver does not tell the o.s. during the handshake its bit depth/channels/max freq. that it supports. And while win or macOS just use a standard 16/48 Android needs those infos to send the audio.
In android audio works (with my nexus 5 + OTG USB cable), I tried with youtube and a signal generator I had.
If you need, also try neutron music player that uses direct USB access.
I didn't explored it, but I had neutron previous configured for direct USB access and it works.
https://play.google.com/store/apps/details?id=com.neutroncode.mpeval
EDIT:
On the subject of the 48Khz limitation, here you can find detailed information about the USB audio implementation in STM32:
https://www.st.com/resource/en/application_note/dm00189562.pdf
I only opened the doc and didn't read it, but I could see they use the internal 48Mhz OSC and a 1000 divider and that limits the supported sample rates to 48Khz. I didn't investigated further to know if other dividers are possible or external clocks are supported for USB audio.
Jan 12, 2019 at 9:19 AM Post #1,491 of 3,717
New Zishan DSD owner here. :astonished: Firmware 0.4H.
I just inserted a 200Gb micro SD (exFAT) with 11,000 files (.mp3, .flac) and the player keeps crashing.
What's the solution? Is 200gb not supported or is it the format or what? Thanks!:construction_worker:
Jan 12, 2019 at 11:31 AM Post #1,495 of 3,717
EDIT:
What android versione do you have on your nexus? I tried on my Lg v20 with oreo and on my XZ Premium with pie and it gets detected but it doesn't reproduce anything
Jan 12, 2019 at 12:33 PM Post #1,496 of 3,717
Stock android 6.xx marshmallow in nexus 5.
Lineageos android 7.xx in LG tablet.
Stock android 8.xx in xiaomi A1.
First 2 with micro usb cable + OTG cable.
Last one has usb type-c, used the same micro usb cable + USB to type-C adapter.
They all work, tested with youtube.
What cable are you using?
EDIT:
USB type-c cable connected to type-c phone + usb OTG adapter connected to zishan didn't work.
Jan 12, 2019 at 4:54 PM Post #1,497 of 3,717
EDIT:
Micro usb+type c adpter. The adpter works eithflashw drives. UAPP recognize the zishan but then no sound.
I just bought amazon micro usb to type c cable... Maybe it's the cable but I don't think so
Jan 12, 2019 at 6:14 PM Post #1,498 of 3,717
Is one side of your adapter female usb2 and the other side a typec and you can connect usb2 pen drives to the phone with it?
If so it should work with zishan + a male usb2 to male microusb cable.
Jan 12, 2019 at 6:47 PM Post #1,499 of 3,717
I
It Is like this but it''s like I wrote above. Get detected but no sound. I'll per you know when the Amazon cable will arrive, it would Be useful because I would use it a lot with Tidal
Jan 12, 2019 at 7:03 PM Post #1,500 of 3,717
I don't have UAPP, do you think it could be a conflict with that (if you have it in both phones)?
When you connect it, the phone shows a message that UAPP wants to use USB and you say no and try youtube?
