I just bought the quables y-split. it's a little bulky but it looks really professional. Only lesson learned is that I need to superglue my wires to keep the twists from unwinding overtime. Parachute cord is also the worlds best sleeving. It's tight over 4 conductors, and a tad loose over 2, but it will work for both, it's low profile, it's soft, tangle resistant, and not microphonic in the least bit so far as I can tell.
Is that the snap on Qables one featured in a post above, as if so I can't help but think it looks hideous XD I'm glad you mentioned paracord though, I was wondering how you use it exactly as I thought it had cords at its centre? I'd love to know how to use it as the styles it comes in are perfect for sleeving.
http://www.yewaudio.com/ - Makes fantastic custom Y-splits out of wood and acrylic of many styles. Also does matching connectors if you want.
Prices are more than reasonable considering the rest of the competition and really a total lack of options out there. Website is under construction right now but you can still contact him.
He does great work.
Example:
http://www.doublehelixcables.com/store/index.php?main_page=product_info&cPath=4&products_id=118
Newly released Y-split by DHC. Looks great; Small, light, and sexy. Still a handful of free upgrade finished available since they are new.
Current pre-order price is $9.99. On the expensive side but not bad at all when you consider the quality, and again the lack of other options.
Only weighs 4 grams!
Finally, look for local places that sell beads. I found some really cool shops near Laguna Beach with what seems like and endless selection of beads. Keep a drill handy and you can make some pretty sweet custom Y-splits. Sorry, no picture examples for this one.; However, I did do two projects with woods bead from Hobby Lobby.
For these, I like to place some heatshrink underneath until it feels like it will compress and be snug when sliding the bead over it. Then I add a small bit of super glue on the heatshrink and slide the bead into place over it. I usually do it snug enough so no glue is needed, but I figure it's a good habit to put a little bit for thermo expansion during season changes.
I lied, one more and I'll stop the TL;DR post. Lunashops.com. Search for "y split". You'll come up with a few results that look similar to this:
They are intended for IEM/CIEM cables but could be used on normal cans depending on the style you go with. Cheap and worth a shot, but shipping takes a while. Just order some, forget about it, and then be surprised when they arrive.
Viablue offer a smaller one now, i will try and take a pic of one when i can. Not a fan of Y splits you have to hold in place with some sort of glue/hot glue.
Here's the small Viablue next to the larger one, also Acrolink one's. All of these need some form of glue to hold in place unless using the correct sized cable.
