Skylab
Reviewerus Prolificus
Where can you find the Mullard 6080 at 17.50 each??? Give me some clue pls.
Right here:
http://langrex.co.uk/images/valves/6080%20Mullard.jpg
10 GBP each.
Right here:
10 GBP each.
Is my tube a goner?
I just tried to put my new TS-7236 in my WA2 and felt something cracked, I took it out, and the small black plastic middle pin at the bottom of the tube broke and stayed in the socket. I managed to get it out of there, but the tube is now without it. Can I still use it? If I do, how will I know the direction of which to put it in the socket?
Put back the 5998 pair... really wanted to hear the 7236 tonight![]()
not sure if its all in my head or if the tubes are now burned in, but i felt today was the first day my wa2 really wow'd me. it was good before but today it was something different.
Which tubes are you using?
Once, after a surgery, I took a substantial dose of Oxycodone for the pain, and my system suddenly sounded like a six figure system.
1) I have had Senn HD600 since their original release - I like them. But eventually planning on buying close cup headphones for times when I don't want to disturb others, maybe D7000 - since it gets a lot of praise here. Would WA2 work for both? Would I be better off with WA6? (I'd hate to spent WA2 amount on WA6SE since I'm loosing tube pre-amp feature)
I am making this choice right now as well. I think I'll have a hard time knowing I could have had better parts in the amp than the standard version, even if the sonic differences are minor. Like buying a car with the smaller engine, there will be that day when you want more power, and you could have had it, but chose not to go for it. I've been there, and swapped engines.
I'm still trying to talk myself into the maxxed out WA2 over the standard version... I'm almost there!![]()
