I want to discuss a little about an iem that has secretly been gaining some traction both on head-fi and in the Korean community. A reviewer from Headfonia awarded it as “the best IEM I tried this year, period” and this, in tandem with some head-fiers touting it with great praise, seems to have raised eyebrows of many for sheer curiosity's sake. I hesitated to leave an impression as I do not own any iems for an extensive side-by-side comparison. But after receiving a handful of humbling requests for impressions, I was prompted to sit down, listen, and decipher this mysterious iem - because that is what us audiophiles do
Nostalgia Audio Camelot
Chain of gear : LP6Ti -> Stock cable -> Camelot -> Stock black silicone eartip
Camelot is one of those iems where I felt burn-in was absolutely vital. Out of the box, it sounded dark with a rolled-off treble and a noticeable veil hovering over the midrange. The bass was slightly loose bleeding into the vocals and didn’t inspire any emotive listening time (even after cable and tip-rolling through my entire arsenal) until I gave it a good extensive burn-in. Burn-in did solve my biggest issue by lifting up the aforementioned veil and revealing a clearer midrange with a more articulate treble response. The bass also tightened up and became better controlled into its own compartment.
Its general signature is of a L-shape where the bass takes the center stage and the vocals and treble take half-a-step back. It is a slightly darker signature, but the details, clarity, and resolution are there that you wouldn’t necessarily find it lacking or veiled during critical listening sessions. It reminds me of the Xe6 a little where the upper-mid range is pulled back in comparison to the harman target. If you find the Harman target too bright or forward, this should work well for you.
Soundstage leans closer to disappointment, as my $1k Ov800 (my favorite iem in the “budget category”
) sounds more expansive with better height, width, and depth using the same stock cable that comes with Camelot (when paired with LP6Ti). It is certainly of a more closed-in presentation where it places you at the front row of a concert rather than giving a theatrical or cathedral-like performance. By 2022 and soon-to-be 2023 standards, I would have expected more from a $2k+ iem as it can get claustrophobic during intense analytical listening sessions.
Its imaging and separation are evenly in line with its mediocre soundstage. Instruments are well separated with acceptable imaging, but I recall Mest MKii to have a more convincing presentation to spatially delineate instruments within its relatively closed-in bubble. With that being said, it has great cohesion to allow all parts of the frequency to flow smoothly from one to another.
Treble is its biggest shortcoming as this is one of the weaker EST implementations I’ve come across irregardless of price-range. The upper harmonics comes off a bit muted with a noticeable roll-off in the upper treble. Its treble lacks a bit of note weight that I find it being less ethereal and lean closer to wispiness, which I can foresee being a deal-breaker to some. If you found the Legend Evo too dark, it would be difficult for me to recommend Camelot with confidence.
Fantastic bass reproduction. This is what you’re in for if you’re thinking of owning a set yourself. The very first time I heard Camelot, I was taken back by how visceral its bass was with its textured oomph that I found so pleasantly addicting. Give it a good burn-in, let the drivers settle, and it will rattle your brain to the point of satisfaction. It does not have the abyssal depth of EVO, the incredible bass-air of Trifecta, or a woofer-like physicality of Xe6 - but this is a competent bass that I believe would satisfy the ears of many.
At the $2600 price range, Kublai Khan is its direct competitor - so logically, I took a trip to a local audio-store a few days ago to do a direct A/B comparison with the Camelot to see how it compares. After a forty-minute subway ride, imagine the shock on my face as I reached into my pocket to discover that I forgot to bring my DAP with me…
Thus, as an apology, my comparison review will be based on sheer memory, which is subject to being fallible due to the inconsistency of human hearing and memory. With that being said, I was able to hear the Kublai Khan just several hours ago so its sound is still quite fresh in my mind.
From memory, Kublai Khan has a more enveloping stage that expands in all directions with a more holographic presentation. Kublai Khan is more subbass oriented with a slightly thinner note-weight, and has better detail retrieval with more sparkly and extended treble. Camelot is comparatively darker with a noticeable roll-off in the upper spectrum of frequency. There isn’t much air in it and I can imagine it’ll come across a tad muted in direct comparison with Kublai Khan. Kublai Khan’s bass extends deeper and lower, but I’d attribute that to its BCD doing the magic within, as it sounds like the bass comes from right beneath you. With that being said, the sheer bombastic quality of Camelot’s bass is more engaging and palpable to my ears. Camelot's bass has a surprising amount of texture and weight, while coming just shy from approaching bloom. Kublai Khan has a better sense of dynamics and the gradation of scale in notes is more noticeable than on Camelot.
I wouldn’t like to call Camelot a bass-head iem, but its bass is truly the star of the show that carries itself relevant. For those who prefer a more reigned-in midrange that strays away from the Harman target, you may find the vocals to be soothing and sublime. I, unfortunately, am of the crowd who prefers a substantial gain in the pinna-region that follows closely to the Harman target - hence, the tuning does not work for me. I do think its treble has a lot of room for improvement. Tuning aside, the lack of extension is evident to my hearing and I believe this may be a deal-breaker to some.
I honestly think Camelot will have its audience, but unfortunately, I do not see myself as being part of that crowd. With that being said, if Nostalgia Audio comes up with a better Camelot that retains its bass quality but with an improved soundstage, imaging, and treble, I will absolutely revisit as I had an enjoyable time with this set.
On a side note, I found their Lancelot cable to be quite excellent at $1200. Absolutely one of the better “value” cables I’ve come across that seeks to compete with the much more expensive cables in the market. Its holographic imaging was immediately noticeable and I can vouch for the Lancelot for those who may be interested.
I hope this review was helpful for those who have been curious!
And please note that this was simply my impression and opinion through the only source I’ve had available. My impression may change on a delta-sigma dac, as it was only listened to through LP6Ti.
