Which Campfire Audio IEM is the AK Pathfinder like?
AK PATHFINDER IEM (July 2022 - $1,899)
The AK PATHFINDER becomes the second collaboration with IEM manufacturer Campfire Audio to produce in-ear monitors (IEMs) under the Astell&Kern brand. Pathfinder is a newly designed hybrid IEM not based on previous Campfire IEM.
PATHFINDER has a new Dual-Chamber Balanced Armature (BA) Driver from Knowles for the key part of the midrange, two BA drivers for high frequencies, as well as two dynamic drivers with a hybrid diaphragm that create bass and midrange.
Knowles’ new ‘Dual Chamber’ Balanced Armature Driver, used for the first time ever in PATHFINDER, is an innovative driver in which a single coil operates two individual diaphragms. It’s like a twin cylinder engine – delivering more horsepower and smoother operation compared to one with a single, larger piston.
Compared to a traditional BA with a single, larger diaphragm, the all-new design incorporates two chambers, each housing its own diaphragm and drive rod actuated by a single coil, resulting in a higher, more powerful output for its size than any other BA and is excellent at expressing a warmer and more natural midrange.
A Radial Venting Acoustic Chamber, newly developed by Campfire Audio, is applied to Dual Custom 10mm Dynamic Drivers. The 3D-printed chamber design naturally expresses the intense low-frequency sound produced by the two dynamic drivers while preserving the unique sound of the BA driver.
Beryllium Copper MMCX connectors are more resilient against wear and tear than regular brass connectors, providing a robust mating mechanism; one that is typically made from soft brass. This selection of a harder material extends the life of the component and the earphone.
PATHFINDER comes with three silver-plated copper cables (terminated in 3.5mm, 2.5mm and 4.4mm headphone jacks) allowing the earphones to reach their full performance potential. The silver-plated OFC copper Litz cable is a newly produced flat cable, with enameled silver-plated copper wire conductor to offer clearer, extended sounds. The flat cable prevents tangling, can be wound for easy storage, and has minimal cable distortion. It is over-molded for increased durability and finished with a metal housing.
