The Takstar, Technical Pro, Gemini Greathon, CyberX, Qpad Thread
Jun 18, 2013 at 4:16 AM Post #856 of 4,701
Hi,
I have the Qpad HQ-85 which seem to be the same headphones as the HI2050.
I would like to buy some leather pads for these headphones. As I am living in Germany I would like to buy them in a German online store like amazon.de if possible.
Can you suggest me some cups or another headphone model of which the pads should fit on the hi2050?
Thanks.
Daniel
Nice find, I will definitely recommend those for gaming headsets in the future.
Jun 18, 2013 at 7:54 PM Post #857 of 4,701
Hi,
Thanks.
Daniel
I would assume the leather ear pads on the Takstar Pro 80s will fit the Qpad HQ-85 (Hi2050).
But have never found the pads sold by themselves.
Jun 19, 2013 at 11:51 AM Post #860 of 4,701
Do the hm5 pads fit the 2050's? Does it change SQ/Comfort?
Yes they do. For me they improve the comfort a lot. Do not remember the sound with the stock pads. Since I like them so much with the hm5 pads that's all I have been using for å long time now.
Jun 26, 2013 at 11:44 PM Post #863 of 4,701
The main con that I had with them is that they're bright and a little sibilant in the beginning and the clamping is tight. They do mellow out after a while. Bass is nice and not excessive.
E: Forgot to mention that the clamping will go away after time and become super comfy.
Jun 28, 2013 at 4:05 AM Post #865 of 4,701
I´m on the verge of buying the HI 2050, for those who have bought from Aliexpress, which sellers have you used or are reliable to you??
http://m.aliexpress.com/item/577556871.html
Bought when they offered a 40 % discount. Probably not the best price on Aliexpress now but my experience was positive - fast shipping, no problems.
Jun 28, 2013 at 6:15 AM Post #867 of 4,701
I'm looking for an upgrade to my beloved HTF-600, which I find just about perfect. However I'm looking for better build quality, tighter clamping, and a little more clarity. I'm quite satisfied with the quality and quantity of bass that the HTF-600 provide. Would the HPT990/ HI 2050 or the pro 80 be a suitable upgrade? I'll be running them through a zune HD and a Samsung Galaxy s3. Will I need an amp and if so, what would you recommend?
Thanks
Jun 28, 2013 at 6:49 AM Post #868 of 4,701
Hi,
Thanks.
Daniel
I found Qpad HQ-85 has exactly the same specs as HI 2050.
http://www.qpad-germany.de/de/shop/a:46,rc:3,n:kopfhoerer-qpad-qh-black
http://www.takstar.com/eng/view.asp?id=642
Jul 5, 2013 at 12:37 PM Post #869 of 4,701
Hi Guys
Thanks to the recommendations here I already own a pair of HI2050 and am very pleased, will upgrading them to the Takstar HD6000 bring about a significant increase in the quality of sound? I searched the forum but was unable to find a comparison between the two.
Many Thanks
Jul 5, 2013 at 3:17 PM Post #870 of 4,701
I all so would like to hear more HD 6000 owners post their opinion on the HD6000.
