Marximus
- Feb 28, 2007
my HTF600 are out for delivery! color me excited!
*Color color color*. You are now excited.
Very nice mods.. For gaming.. I would absolutely advise the velours for you. I like how there is added air to the sounds when gaming. Almost sounds like a open phone. Adding to the comfort level as well. That mic I might have to try that for myself as my clip on mic people are just complaining that my voice quality is not good. Have to go in and out of vent just to get the volume up. Speaking of gaming.. EVERYONE needs to get BF3.. If you guys play one game a year.. This game has to be it. Just simply phenomenal!! =SOC= 24/7 CQ Maps My clan 64 man PC server.. Look for it if you guys play the PC version.. I hear the console versions are all playing smooth too..The HTF600 sounds stupendous with the game. Bullets, explosions, the carnage is insane!
The soundstage is slightly on the narrow side since it's so up-front sounding, I think it has to do with the driver being so close to the ear, if you drag the cups just slightly outwards from your ears, it already starts sounding a little wider as the drivers move further away from the ears, I think this is what I figure made me dislike D1100 as the drivers were positioned very deep inside the cups (maybe like 1.6~2cm) and that's the reason behind the huge soundstage for a closed headphone but it was like too "distant" sounding for my liking.
Hopefully I could get my mom to make those custom pads for me tomorrow, I might see if she could try make them just tiny bit thicker so my ears wouldn't be so close to the driver for a wider sounding stage perhaps.
My plan for the pads are:
- Like half of the pads or the underside being made of leather/pleather and the front of velour
- Slightly bigger innerdiameter for the ears (ie smaller/more narrow padded area)
- Slightly thicker pads to get my ears slightly further away from the driver
I might go right away and try adding something on the pads to see how it really starts sounding like if moving drivers a bit more further away from the ears.
How about making a foam circle and inserting it in the stock pads? That will bring them out further. Not much room though. My RX700 has that mod. IT helps.
EDIT. I just did it myself. Definitely widen's the soundstage. Niceeeeeeeeee..
Yea I was thinking that too after being unsuccessful finding something that I could just stick on top of the pads. There's actually plenty of room beneath the pads, not very tight at all so you could actually make it stick out quite a lot this way too. What "foam" did you use, I'm having some hard time finding something worth sticking under them, may have to use toiletpaper lol.
EDIT: Yes it worked nicely! I definitely approve this as a very easy soundstage enhancing mod. Just need a piece of papertowel for each side as that will have the perfect length that you roll into like aprox 1cm wide paper tube/roll and stuff inside:
EDIT: It might actually have increased the bass response a bit, that's what my early impressions tells me. O.o I would be very interested in hearing opinions on this mod from velour pad users.
