RPGWiZaRD
- Jan 31, 2010
after a couple of weeks , these are obviously better than the first time..
finally , i think its a very good headphone!!
The only problem i have now is that if i push the right cup the sound is stopped(or produces very very weak sound) ..i can solve this by pushing it again..(the push is not so strong , just a little..) that time i hear a little sound like something was back in this place..
What should i do now?Should i open it and take a look? Left cup is excellent and does not have this problem..
It's a very common issue with these headphones which has been brought up quite a few times in this long thread, the diaphragm (the membrane surrounding the driver) makes the driver get stuck in wrong position somehow (probably too big or loose) and you have to for example blow towards it to push it back into position. Like you said you'll hear a "click" when putting the headphones back on and then you know it got into the right position again. I accidentaly dropped my pair of HTF600 and since that, the problem started appearing but only on the left side and yea pushing gently on the cup may be enough for it to happen, seems like the "suction"-effect is quite strong with these default pads as it doesn't seem to let any air through (it also gets very warm easily) so as you push onto the cup, the driver gets "sucked" into wrong position.
