NateZ28
- Jul 13, 2011
How do the Beyerdynamic Velour Pads effect the sound signature? Specifically the bass?
So finally got my HTF600 delivered to me
First impression, these are less bassy than I thought they would be
Burn them in, they will get bassier after burn-in. I was also underhelmed by bass response at first. Compared to M-Audio Q40 they are about equally bassy probably only something like 1dB difference in favor for Q40. I do think the HTF600 have a peak in the bass boost up to 10dB or so (around the midbass frequencies and at least +5dB boost at say 30~50Hz) even which is a lot but it doesn't truly show until it's been burnt in.
Thanks, burning them in now but I'm a bit skeptical that burn in will magically 'add' bass
When I burned in my Pannys, the bass didn't become any more prominent. In fact, I think it got less prominent, but it was more refined.
Just wondering if this is normal,
the cut in the foam on both drivers?
Leave them burning over night. And then try them. Will make you a believer.
I did the same thing. I can't believe they still sound the same. Must be tough.
