Hope there will be an adapter available so that some of us could use our existing cables that have a 2.5mm balanced plug.
The Official Sony NW-WM1Z/ NW-WM1A Flagship DAP (Live From IFA 2016)
- Thread starter thatonenoob
- Sep 15, 2014
3rd party support should be fast in the coming I think.
I hope so, coz even if the sound quality ends up being the same as the AK380cu, I might just switch over just for the battery life alone.
- Sep 15, 2014
Indeed. The spec sheet battery life is quite good (though real tests may reveal different results).
ashn2k
- Jul 1, 2009
I doubt its sound quality could justify its humongous price, since when Sony make 3k$ DAP
- Sep 25, 2010
Probably been answered but i couldnt find the answer.
Difference between black and gold models - is it purley astetic? Do they have same internals?
nc8000
Twice the memory, better internals, twice the weight
Mmm.....in addition, use of kimber wiring and a copper chassis, an obvious nod to the Ak 380 cu. Also, it is more than twice the price tag.
- Sep 25, 2010
Thanks is there detailed internal spec differences published anywhere ?
muzic4life
- Sep 14, 2012
Yes, I'm going to go to the office today to pick up the Elear and Utopia, neither of which I expect will be any trouble to drive for the NW-WM1Z--they're both very reasonable headphones to drive. I've so far been using only the MDR-Z1R, FitEar MH334 custom, and Noble Prestige (Kaiser 10) custom with the NW-WM1Z, so I'm now curious to try many others.
Hi @jude,
Do you mind telling me how's the pairing of wm1z with mh334? Are they a good match?
Thank you!
Muse Wanderer
- May 17, 2014
The output impedance of the WM1A would be nice to know but apparently it is top secret!
The ZX2 pairs well with the CA Andromedas - OI probably 1.7-2 ohm
If the WM1A has lower OI than it is a no-go for me as the Andro will turn into a bass monster as it did with the Mojo!
- Sep 15, 2014
Yes the output impedance has not been officially been released. When asked, the engineers gave this instead 250 mW into 16 ohms.
nc8000
Well the designer of the ZX2 said that in his oppinion output impedance is irrelevant so could see no reason to say what it was. I assume the same goes for these new players
- Sep 15, 2014
I don't believe the designers of the ZX2 and the WM1A are the same...but this does seem to be a generally shared opinion amongst the engineering team.
Muse Wanderer
- May 17, 2014
Yep, but it matters to me!
The Campfire Audio Andromedas are notoriously sensitive with sensitivity going down to 4 ohms in the bass region!
Pairing it with the Mojo whilst great sounding was way too bassy for my neutral taste.
The ZX-2 apparently is a great pairing with probably ~2ohm output impedance. QP1R with its 1ohm OI was finish too.
Any lower OI is too much for these IEMs.
