The Official 64 Audio Thread | apex & tia Technologies
Aug 5, 2022 at 1:06 AM Post #20,806 of 23,601
Still rocking my Duos. I used to have the U12ts a while back but kept my Solaris 2020 instead of them.
I still have the Solaris, but my Duos get all of my listening time. They just sound more natural and open to my ears. I keep thinking I should do an AB again, but I can't be arsed.🤣
If I had the chance to try the U12t again, I'd love to put them against the Duos though.
Aug 5, 2022 at 3:51 AM Post #20,808 of 23,601
I have a pair of Fir Audio V x Vs, and a pair of U6Ts on the way. I can't wait!!!
Congrats on the U6t, the “little IEM that could” out of 64’s lineup imho.
When you just want to listen to your music here, there, or anywhere with no fuss no muss, the U6t gets it done.
Aug 5, 2022 at 6:38 AM Post #20,810 of 23,601
There are tons of options to read FLAC files on your iOS device, just type “FLAC” in the App Store search bar :)
One solution that I find more polished is the VOX app
https://vox.rocks/iphone-music-player
They also have a have a cloud with unlimited storage where you can store all you FLAC, DSD and other HiRes files to play them on the go (of course you need a subscription for this)
https://vox.rocks/vox-player-premium
Thanks for all this you all- never been able to get any of my FLAC library to play from iPhone, translated it all to ALAC or AIFF. No longer.
Aug 5, 2022 at 6:40 AM Post #20,811 of 23,601
How do U6ts cp to Duos?
Aug 6, 2022 at 5:07 AM Post #20,812 of 23,601
So I will be auditioning the TRIO which should arrive Monday! And have a good 4 days with it as the wife and kids are going out of town . My question is which tips do you guys req so i dont waste to much time tip rolling ! Or are the stock is best?
I have a few tips already
UM blue heart
Azla sendaear light short ( what i use for my MEST OG)
Azla xelastec
Spiral dot ++
Kz starline / inverted
Kz Blue foam tips
New bee foam tips
Thanks in advance!
I’m very excited!
Aug 6, 2022 at 5:30 AM Post #20,813 of 23,601
Off Topic but does anyone know where I could listen to a pair of Fourte in central London?
would like to add a pair (used) to complement u12t and intrigued by Fourte but reviews and opinions are just so polarising so feel the need to listen to before pulling trigger.
G
Aug 6, 2022 at 7:46 AM Post #20,814 of 23,601
UM blue heart
Azla xelastec
Spiral dot ++
Kz Blue foam tips
New bee foam tips
Thanks in advance!
I’m very excited!
I use the spiral dot
Aug 6, 2022 at 12:02 PM Post #20,816 of 23,601
Out of curiosity, do you push the tips in to sit flush with the nozzle like the stock tips are meant to fit?
That depends on the tips. Spinfit CP100s and the CP145s that come stock with at least the Nio, yes. But you don’t want the end of the nozzle to be flush with the end of the tip. That’ll effect the sound, even if that isn’t an issue for you they insert fairly deep so will have to worry about wax etc. I’ve never had an issue with needing to clean my other IEMs but the Nios,… have to be cleaned every time I use them.
Aug 6, 2022 at 12:08 PM Post #20,817 of 23,601
I have normal spiral dots. Don’t know the stock tips. I don’t have those. Mine go pretty far over the nozzle.
Aug 6, 2022 at 1:02 PM Post #20,818 of 23,601
That’s with the CP145s and the other silicone tips that came with them (I’m not sure how they’re supposed to be useable). You will want to use tips with longer stems. If you use anything with short stems, like CP360, they well get pushed down to the bottom of the nozzle.
Edit: CP100s fit the nozzle the same as the CP145s in this picture.
and end up being flush.
Aug 6, 2022 at 2:21 PM Post #20,819 of 23,601
F28CF181-4394-4FBE-8D79-F80DAE02029E.jpeg and end up being flush.
not sure if i remember this correctly, but being flush is as intended afaik
