The Official 64 Audio Thread | apex & tia Technologies
Aug 8, 2022 at 3:04 PM Post #20,821 of 23,603
Out of curiosity, do you push the tips in to sit flush with the nozzle like the stock tips are meant to fit?
The Spinfit and foam tips will not sit flush with the nozzle, however the stock silicone tips will fit flush with the nozzle and give the most un-colored response.
64 Audio Stay updated on 64 Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/64audio https://twitter.com/64audio https://instagram.com/64audio https://www.64audio.com/ info@64audio.com
Aug 8, 2022 at 3:14 PM Post #20,822 of 23,603
I only use the supplied silicon tips with the Tia Trio (my only universal IEM).
Aug 8, 2022 at 4:36 PM Post #20,823 of 23,603
I have found Azla Xelastics (which fit flush with the nozzle) give a great bass texture because they allow a good seal despite my wonky external ear canal anatomy- it is a really solid assistive device for those of us with atypical anatomy.
Aug 8, 2022 at 10:58 PM Post #20,825 of 23,603
just wondering if there is going to be a new flagship coming soon ?
Aug 9, 2022 at 2:27 AM Post #20,828 of 23,603
Hello all, what cables are you using for your 64 Audio IEMs that cost under $250?
You can try Satin Audio cables, they offer 2-pin flat connector option to match perfectly to 64 UIEMS.
Aug 9, 2022 at 2:46 AM Post #20,829 of 23,603
EA Cadmus + A12t = 🥰 (I suspect A6t would be the same)
Aug 9, 2022 at 5:20 AM Post #20,831 of 23,603
Pls could you provide a detailed impression vs U12T stock cable on U12T various reviewers on Head-Fi are saying Cadmus has elevated but well-controlled bass but less extended detailed treble vs others who report it has less elevated bass and more extended detailed treble. @CrocodileDundee, what is your experience?
Aug 9, 2022 at 7:16 AM Post #20,833 of 23,603
Fastest delivery ever!! received the TRIO
Within 24 hours .
Tested all tips with dawn lit metropolis iii consider and kill jill big boi
Just to see which tips ill use for the next 4 days
Tried it with spiral dot ++, Um blue heart , azla short lights and stock CP (somethings)all sounded exactly the same ! All were Decent seal
Nice bass !
Tried with the kz starline and it fit the nozzle super tight as in it looked apart of the nozzle and went straight in my ear canal BUT not a tight seal at all can fall out easily if i shake my head but went deep in BUT they sounded wonderful less bass then the above eartips . Looking for my larger size kz
Hmmmm….
Aug 9, 2022 at 9:09 AM Post #20,835 of 23,603
Kz starline small tips on the trio
It goes straight in the ear canal very deep but not a perfect seal but very deep insert.
