Jun 21, 2015 at 9:33 PM Post #9,481 of 20,146
Is that place (Hot Wax?) on 10 St. NW still there? Walked past on my way to SAIT, picked up a few good discs there too.
Still there, but gone mostly vinyl. The Poster Shop (14 St. and 12 Ave. SW) isn't too bad for CDs... mostly older rock, folk and indie.
When you're next in town give me a buzz... Beer would be good.
Jun 21, 2015 at 9:34 PM Post #9,482 of 20,146
Jun 21, 2015 at 11:59 PM Post #9,485 of 20,146
SAIT! I went to NAIT for Architectural and Urban Planning back in the day!
You guys see this? FiiO's new DAC/amp, Q5.
http://www.head-fi.org/t/772186/fiio-q5-flagship-dac-amp-an-dual-dac-usb-optical-coaxial-line-in-share-the-same-amp-module-with-x7#post_11707678
A bit confused with this one, where FiiO is planning to share modular amp design between X7 and Q5.  It kind of makes sense with Q5 to keep DAC section fixed and introduce a replaceable amp modules with different connections, power/impedance rating (like E12A vs E12 vs E12DIY), including regular and balanced wiring.  Perhaps like a principle similar to E12DIY where OpAmp is socketed and you can replace it to change sound sig.  But with X7, would it already come with internal amplifier driving HO?  Then, would they consider a modular amp as an add-on that going to by-pass internal amp routing signal to external one?  So convenience of this external amp is only a little snap-on module instead of rubber-banded stack up?  Is that how you understood it?
Jun 22, 2015 at 12:37 AM Post #9,489 of 20,146
Switching from low to high gain, and then volume matching there is a very noticeable difference in sound
Tried this with the Altone 350s and my X3ii this evening, and you're right. Bass was far less boomy on high gain... very listenable without EQ. Thanks for the tip!
Jun 22, 2015 at 12:40 AM Post #9,490 of 20,146
Treble is much better and more tolerable as well. Glad we could unleash their potential
Jun 22, 2015 at 1:08 AM Post #9,492 of 20,146
Good call, Vince!
How's it work with A250, Eric?
They're up next... I can only listen to one pair at a time!
Jun 22, 2015 at 1:37 AM Post #9,494 of 20,146
Good call, Vince!
High gain tames the 350 beautifully. It becomes nice and revealing, with controlled mid bass and articulate mids.
The effect on the 250 I find less impactful. The bass is less controlled, and mids comparatively more veiled (recessed, less bright). Not sure if this is the single BA not being able to provide the detail and mid/high emphasis that the 350's double BAs can.
To tell the truth, I'm not finding either 350 or 250 as boomy as I found them on first listen... Perhaps I've experienced some brain burn listening to the ESS phones as much as I did in the past couple of weeks?
Jun 22, 2015 at 1:37 AM Post #9,495 of 20,146
Actually really liking the 350 all of a sudden...
Now if only we could de-viagra the cables, and get rid of the microphonics!
