Figure this is a good a place as any to post something about these ESP-9's I've been working on. I was lucky to snag an affordable pair from another HF'er. Well the lucky part remains to be seen as these will remain a work in progress for now.
These were bone stock and even with new Pro 4AA pads they did not work very well; they clipped/overloaded like mad and very iffy sound from both channels. I have a few different amps that indeed let me see that they were in overload condition when anything resembling bass came into the picture.
I've sunk quite a bit of time into these so far and still have a long ways to go in the rehab/refurb process.
-Cleaned the old foam and replaced with hand cut random packaging foams I had lying around - I thought this would fix everything but after about three attempts not even close!
-Cleaned the circuit board contacts on each cup - This seemed to help slightly
-Replaced the capacitors and resistors on each cup - This also seemed to help slightly
-Disassemble and replace the wires that run through the headband with a soldered connection - This required a ton of work and glue but I think it may have at least cleared up the channel imbalance.
In their somewhat current working state at moderate listening levels these actually sound very good, the fit is awful however ~ I suspect the headband arc is ever slightly out of round or my head shape is just too weird. When you get to louder volumes they still clip and lose steam, the threshold for this is what I would consider only moderate listening level.
Next up I will tackle the E9 for replacement of as many components as I can, it's an absolute nightmare but hopefully it will solve or lessen the clipping issues.
Parts seem to be very high voltage ratings 1000v and 1500v for many of them which makes finding modern replacements a bit of a challenge and awkward for fitment. I think it was mentioned by Spritzer previously the bias is around 400v. The diodes from the manual list Solitron MV16A and a 1R175A Zener which is not too helpful. I have gone with SF1600 for the diodes and 1N5955BRLG for the Zeners, hopefully I won't be blowing anything up!
