GumbyDammit223
- Apr 3, 2014
wasapi push or event depends on the DAC but if both work, chances are they will give the same result. and if one creates problems or doesn't work at all, then you've got your answer ^_^ .
KS is kernel streaming, another "bit perfect" solution like wasapi. again if it works without trouble, then it probably also gives the same kind of quality, usually people pick one at random or because the rest doesn't work on their specific system.
direct sound while still usually audibly fine, will often measure a little below bit perfect solutions in exclusive mode. but depending on your usage, having a mixer can really simplify things(fidelity vs convenience).
now to know for sure, I would very very strongly advise against believing posts like mine about what is the best ^_^. to check measurements, just get yourself a cable to go from your DAC to your soundcard's input (if it's not too crappy), and use the free RMAA to check the different solutions. it will take you an evening to test plenty of settings and know for good if something goes wrong. I've done that myself not too long ago when I was testing the recording side of my loop with various settings and usb configurations. but the idea is the same as long as the input isn't too bad to measure anything but itself.
or if you go all subjective about this, just try and pick whatever feels right to you for whatever reason you have. your system, your sound.
Thanks for the advice - good thing it's the start of the weekend!
I did see that quite a few of the options crashed when trying to use the Bluetooth path which helps narrow things down, but the USB path seems to be pretty robust. Glad I'm into a hobby that's so cut and dry for options!
