PleasantSounds
I have a minor problem with volume to my Hugo. Sometimes, I hear some distortion in tracks that are, admittedly, overcooked in treble. Is there a master volume in Foobar that I can try to reduce? I can't use wasapi as I'm still on XP.
Uh, yea, the big volume slider?
With all due respect, and not meaning to whine: I'm a blind dude. What slider. If my JAWS (Job Access With Speech) program can't recognize the slider on the screen, I'm not going to see it either. Thanks for the help, but if your answer was supposed to imply "Duh," it was misplaced, sir.
Is there a way I can access the 'slider' through the menu choices?
Whether you see the volume slider on screen or not will dpend on the actual GUI configuration you are using. For the standard GUI the way to bring the volume slider on screen is to right click on the main menu bar and put a tick next to Volume Control.
If you want to lower the volume permanently, then probably a better way is to do it through Preferences->Playback. On that screen you have the Preamp section where volume can be adjusted. If you're using the ReplayGain, then use the upper slider, otherwise the lower one. Or just change both.
