Dec 24, 2012 at 5:53 AM Post #3,046 of 3,613
Usually I think mp3 uses less battery life. But I've heard if you were using WAV you actually save more battery life than even mp3 :).
Dec 24, 2012 at 5:53 AM Post #3,047 of 3,613
I say don't bother with APE.....who uses that anymore? FLAC and ALAC support are all good. Any time I've come across APE files, the first thing I do is convert them to FLAC.
APE format is more common in China!
Dec 24, 2012 at 5:57 AM Post #3,048 of 3,613
It's still a nice feature to have. I mean if it really saved enough space and still had similar battery life I'd be likely to convert my files on the device (not my actual files) to APE to benefit from the saved space. Although I agree with you I don't see it as a requirement at all. But it shows you their dedication and support as a whole.
Indeed it does, good on them for doing that.
Dec 24, 2012 at 5:58 AM Post #3,049 of 3,613
It'll be a cold day in hell with flying pigs filling the skies before I use WAV on a DAP.
Dec 24, 2012 at 6:10 AM Post #3,051 of 3,613
That day is coming soon then lol. I'm gonna be doing the switch to WAV when the space becomes available and cheaper. I feel the sound is better so :).
Yeah, you've mentioned that before. Whatever works for you!
Dec 24, 2012 at 6:19 AM Post #3,052 of 3,613
I use 24/48 WAV on Rocoo BA, love it. 32 GB is plenty for your HD albums. Unless you use your portable sources at home or you are constantly on the go there is really no reason to need more than 32 GB.
We can get 64 SD and microSD relatively cheaply right now.
Dec 24, 2012 at 6:21 AM Post #3,053 of 3,613
I use a 64GB card in my Studio V :). I have about 2,500 FLAC files and it works great :).
Dec 24, 2012 at 6:36 AM Post #3,055 of 3,613
Good on you, if I was in your case the navigation task would be a nightmare for me.
lol not really. I have everything set up via the resource menu ;). So everything is pretty much how I want it. I mean not as particular as playlists but the files that I wanted are all in the folders I put them in. So its setup like playlists for me. The best way to access music IMO.
Dec 24, 2012 at 7:00 AM Post #3,056 of 3,613
The problem is when I have too many folders I forget what I have in my SD card, and yes I am that lazy to look through the entire folders. The navigation is just a little harder now considering how my up navigation key has stiffened up alot, got to send it back to repair.
Dec 24, 2012 at 7:08 AM Post #3,057 of 3,613
Yeah you have a point there lol. That is one thing I really like about the DX100. Even if I forget where I put a track I can do a search and pull it up and pinpoint what folder it is in or I can just play it directly :).
Dec 24, 2012 at 10:17 AM Post #3,058 of 3,613
Sorry not now because the firmware still not the final version , and the Soc will working in different speed ( up to 600MHz) so I can't answer your question now
Thanks for the response and I'm looking forward to its release.
Dec 24, 2012 at 10:26 AM Post #3,059 of 3,613
yes, you got something and you lost something, a touch screen and a Android system can help a lot to find a sound track or a song. nothing is perfect. we did consider to develop an Android DAP but it is not necessary now because
you can't balance the cost, battery life and the size. Trust me, it will be a nightmare if you want to enter the letters if you have not a big screen like DX100 or you have not the full keyboard like RIM.
Dec 24, 2012 at 10:37 AM Post #3,060 of 3,613
Oops, didn't see the other pages! xD
