DefQon
- Jan 14, 2011
Didn't you own the 2170 package before? Judging from sig....
Can anyone offer insight on the and SRM-323s driver units, is it worth the extra cash? I was wondering if the low end 252s would drive the SR-407/SR-307 reasonably well, it seems that Stax doesn't recommend using the 252s with higher end Lambdas.
I listened to a bunch of Lambdas at a meetup over the weekend, almost a good hour just comparing. I really enjoyed the SR-407 on the SRM MKII (I believe that was the correct amp) and I'm considering a Stax setup now... 307 + 323s/252s is mainly interesting me.
Thanks!
The 404 LE is probably the only Lambda model (other than LS) that I haven't heard or owned. If you want balanced, neutral, slightly more brighter sound sig, the 207 fills the job for the task. I don't care for the 307/407 or 507 models.
How much are you looking to spend? If you're going to be buying them separately, it might run you a little more.
You can get the SRS-3170 (SR-307 + SRM-323S) for under $1000 these days. You'd have to put in some effort to find the SRM-252S outside of a Stax system package, and the bundle discount might make either the SRS-3170 or SRS-2170 more appealing.
Mind sharing what you didn't like about the higher end models? I'd rather pay a bit more now than upgrading to the 407/507 later and wasting more money.
I have about $650 saved right now, but I'm not looking to get over $1,000 or so on the whole setup. So, pretty much 2170 system or a 307 + SRS252s. Maybe I'll suck it up and do 3170 if I can save up longer.
Now, where did you find the 307/323S under $1,000? Cheapest I've seen is $1,100ish.
