autoteleology
Formerly known as Tus-Chan
- Nov 6, 2011
Have you changed the tubes or cleaned the pins? Have you measured the DC offset using a DMM and adjusted it accordingly via the trimpot inside? I smell bad resistor or bad tube. A cap can also be the culprit if in the PS stage/section, is the case with most of the vintage amps where hum would be hearable with a saturated cap.
Yes, I have already done all of that.
