Th3Drizzl3
btw my sivga 006 came the same way i had to flip one around. they are def wider now imo
Sweet. I was able to pick up a spare IEM case (https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/372402693496) for 28 cents
Not sure what you are saying. The modi, all versions, only have RCA out.Amazon is better.
Modi 2
https://www.amazon.com/s?k=modi+2&ref=nb_sb_noss_1
I only went there to see the pic. And I only saw RCA out.
Schiit Saga Active/Passive Preamp with Remote Control https://www.amazon.com/dp/B07QQKNRXL/
Schiit saga is cheaper on amazon w free shipping and a $50 coupon vs the close out price at schiit
Only from the notoriously bad ASR. I've had a Modi 2, and I have friends with it, and it sounds fine. It's a very good deal at $49I usually refrain from knocking a product but would encourage people to look elsewhere than a Modi 2 which is known to have lots of problems with jitter and noise (there are objective measurements out there that show this on some other sites). If you could spend the little bit of extra money, get the Modi 3 which is superior since Schiit fixed the noise/jitter issues. If you can't extend your budget then I would recommend to look at the Topping D10 which is $70 on Drop.
Hiby has some deals up to 150$ off
https://mailchi.mp/e4f08a35fbed/black-friday-huge-deal-up-to-40-off-419241?e
