I'm keeping my eyes on Cardas to see what they come up with (their HD800 cable is in the works). I personally did not feel that their cables were the best for the HD650, but think that their sonic signature (if maintained in the HD800 offering) will be spot on!
The best cable for Senn HD800, Grado PS1000, Denon AH-D7000, AKG 701/2
- Thread starter potter
DanielCox
- Jun 22, 2009
It's not if the evidence (or lack) is on my side - which it is.
Again - prove it.
Originally Posted by carledwards /img/forum/go_quote.gif Much disagreement on that; certainly I disagree. Cable differences may not be the most dramatic in the chain of components but to claim they don't exist is plain wrong. |
Originally Posted by Acix /img/forum/go_quote.gif It's not dramatic as the amp, but can help with a better instrument separation and more body to the sound. Overall improvement of 10 to 15%. |
Again - prove it.
Acix
- Jul 7, 2008
lol, buy it, or make it, and prove to yourself. What I'm interested in is to compare my K702 recable with Mogami W2534 to Aloksatoor from page 1, that maybe has the K701 with the 22 gauge ultra jena.
DanielCox
- Jun 22, 2009
I don't have to - all the studies show there is no difference.
In the end you can buy cable if you want - it makes it look nicer at least but don't be expecting any SQ difference because there isn't any.
JaZZ
The placebo effect works perfectly for me.
– I'm probably going for the Blue Dragon.
KevinR70
- Jul 14, 2008
I would vote for the SAA Voice cable hardwired to the 800's. I've only tried the stock and the Voice, but the difference between the two is not slight. The Voice, though expensive, brought the 800's to another level. The lows are much improved and the harshness on the high end I used to hear on some tracks with the stock cable is gone. Worth it IMO, based on money I spent before the cable upgrade on components and other areas in my system trying to get the 800's to sound like they do now with the Voice cable.
Bullseye
- Nov 25, 2008
Stock cable
PERIOD
PERIOD
Fafner
- Oct 26, 2003
We really needed another thread ending into a cable debate, I missed that so much.
btw...
"I made some tests and couldn't hear any difference" --> Ok, one can agree or not agree but at least it's an opinion based on experience and it can be discussed
"Science tells it doesn't make any difference but I never took care of test it myself" --> Fail, not even worth to discuss with...
btw...
pompon
- Dec 25, 2006
Many peaple tell stock and don't even tried another cables.
I have stock, equinox and balanced equinox for my HD650 and it's major upgrade for me.
We just need meet with stock hd800, equinox hardwire hd800 and Apure or other brand cable with HD800 and peaple will be able to test that.
I am sure the voice is better ... but is the 200$ cable is good enough to don't worry about the voice ?
hh83917
- Jul 31, 2006
i think the cables doesn't make much difference, but if you are going from stock unbalanced cable to balanced setup, then that's a different story.
I'm planning to get the hd800 too and wait for the Zu cables to come out...
nullstring
- Oct 24, 2008
when I recabled my D1001 the difference was -very- obvious.
Therefore, I will forever be a modest beleiver in cables.
I also want to note that the difference was not necessary positive. This is what makes me certain that it's no placebo effect.
In the case of the D1001, the mid hump was removed.. highs were much more brilliant, and the bass was significantly... boosted.
I've been meaning to do a markl mod on them to rid of the boosted bass... for now I've just been using an equalizer in combination with them.
leeperry
Galvanically isolated his brain
- Apr 23, 2004
what is SO laughable on the K702 is that ALO add a killer cryo litz braided cable + Furutech....but they keep the lousy stock connection between the 2 cups, which is :
1)"cheap" stock wire
2)very poorly made from what some ppl said
AKG 702 Reference Headphone WITH ALO new SXC Mico CABLE
when you ask ALO about that, they say "yeah well, it still sounds better than stock anyway"
so what about all the usual cable seller bs? you know inductance, dielectrics, 101% pure copper yada yada
that's the key IMO....using some random cable on a random phone is a major hit & miss.
if you have plenty of time and different wires, at some point you should be able to find a cable that changes the phone FR in a positive way(fixing some notches here and there).
Originally Posted by Acix /img/forum/go_quote.gif lol, buy it, or make it, and prove to yourself. What I'm interested in is to compare my K702 recable with Mogami W2534 to Aloksatoor from page 1, that maybe has the K701 with the 22 gauge ultra jena. |
Originally Posted by nullstring /img/forum/go_quote.gif when I recabled my D1001 the difference was -very- obvious. [..] I also want to note that the difference was not necessary positive. |
spinali
- Sep 26, 2003
Even cable fans agree that cables don't offer a significant difference in sound - anywhere from 10-15% to zero. Double-blind tests indicate that there's no difference at all.
Then again, a few users seem to hear a difference after cable burn-in - a forbidden topic best ignored.
Lil' Knight
- Sep 16, 2007
I remember a company offering a K702 cable like this, but terminated in balanced connectors. Priceless.
