No, the human ear on the other hand is far from perfect.
While I am as far from a religious creationist as it gets, the popularity of One Direction must surely be a sucker punch to the theory of evolution.
Using real time high resolution resampling software, based off interpolation algorithms that create the waves perfectly when compared to the sampled waves.
If the DAC uses a simple linear resampling, the created waves look like steps on a staircase, while in high resolution, they are curved lines.
The step things create alaising, and harmonic distortions, due to the fragmented movement of the driver. They also have other problems.
Example down.
You can come to my place for more details.
This is how sampled waves look like in computer, 1Khz, 10khz and 16 khz, created with free software audacity
This is how they look after resampling using a high resolution resampling algorithm:
In real life, waves must always be curved lines, and never have straight lines or corners.. It sounds much better with high resolution capable DACs.
Just try hqplayer. My algorithm is optimized differently, trying to do a different thing.
I see you guys have been very busy feeding our resident troll.
Just want to introduce two words to the ultrasonics discussion. Intermodulation Distortion.
se
you're a few pages too late![]()
Intermodulation distortion.
I had thought about that. But i thought that if it was meaningfull for what you can hear, the microphone should had already picked up on it.
se
wondering what the frequency response is of the mike that's recording all this ultrasonic stuff?
You can find mics that exceed the high frequency limits of us meat popsicles, however, I don't see what value it can possibly contribute unless one is an ultrasonic troll.
I assume the mics we're referring to are recording studio mics. So I'm wondering why they would be calibrated to pick up stuff beyond human hearing? If that's the case how did this ultrasonic stuff come end up on a recording? Never mind the filtering that might be done during mastering.
there are lots of albums with ultrasonics. I had my hands on one few days ago, it sounded, very very good. But i do not think that it had anything to do with the ultrasonics, i manually filtered the ultrasonic data out, and it still sounded very good.
I can sum it up in a common acronym, BS.![]()
