Yuri Korzunov
Member of the Trade: AuI ConverteR 48x44
- Sep 18, 2014
Thank you.
DSD DAC divide 1 output to 2 lines or it's 2 DSD DACs?
Note that in most cases with a single output from the original source (DSD in this case), you will need the PCM loop input and output both through the switch box. Essentially, like a tape loop.
Thank you.
Thank you.
Depends how complicated you want to make the diagram but that should be enough for the basic premise.
After all I left out the amplifier too...
Heck, you can even use an ABX comparator with speaker (or amplified headphone) level capabilities for comparing level matched amplifiers!
It's deliberately simplified, so it's basically assuming either there are two separate outputs or that you split the one output to two lines. If it only has one output, a tape loop like BlackbeardBen suggested would be the way to go.
A good hardware ABX comparator is going to have a tape out/in function to allow a single input to the comparator looped out for processing and thus comparison with a pass-through.
Right. But it seems there's still some confusion.
However we will compare 2 systems (i.e. devices) not formats.
I correctly understand gist of experiment?
Since you need different hardware to play DSD and PCM you can only test differences between the formats indirectly. If DSD is audibly superior to PCM then the addition of the PCM ADC/DAC conversion should degrade the signal and produce audible differences.
You can't strictly conclude that that one format is superior or that the they are equivalent with this method because there is different hardware involved, but it's like that with every other kind of test you could do since there's always hardware involved somewhere.
Actually BlackbeardBen is right on this one. The key phrase is...
We're not talking about digitally converting a DSD file to PCM, we're taking the output of a DSD DAC, feeding it into a PCM ADC and then out through a PCM DAC. This sidesteps all the issues about conversion quality and filter optimization since there is not digital format conversion and there are two separate DACs. If DSD has "something" audible which PCM doesn't, then the ADC/DAC loop will degrade the signal and get rid of that 'something', whatever it may be. If you can switch the ADC/DAC loop in and out without audible differences then the conclusion will be that PCM is at least as good as DSD.
I'd forgotten about it before, but this is is a pretty standard way to test formats so different that they can't be played back with the same hardware. For example, there have been tests where a PCM ADC/DAC has been switched in and out while listening to vinyl and people couldn't tell the difference either.
When you say that not all DACs "sound the same", what do you mean? It doesn't seem like people are able to ABX differences between *competent* consumer-level DACs, so I'd hope that pro-grade stuff is even more transparent.
If they all have distortion figures below audible levels, and a full frequency response, and a low enough noise floor - any differences should be inaudible to the human ear. So literally, some say all DACs sound the same (ES9018 no different from a WM8740). Some mean it to say they all sound the same in ABX testing as well... depends on who you ask.
Actually, you've got it a bit backwards there..... the filtering, and so the potential to alter the sound as part of the conversion process, is much MORE extreme with an A-to-D or D-to-A conversion than with a relatively simpler digital-to-digital format conversion.
When you play that DSD file through the DSD DAC, the DAC is going to alter the sound (because filtering is applied by the DAC), then the PCM ADC process is going to apply filtering, then the PCM DAC is going to apply filtering again .... You've gone through THREE separate conversions, and each of those conversions is going to alter the sound. You're also starting from an assumption that the output of the DSD DAC is at least good enough to count as a "source" for the sake of our test. (What if the DSD recording sounds different, not because it's somehow "capturing something that PCM is missing", but simply because it's coloring the sound? If that's the case, then we'd also like to know that.)
