analogsurviver
- Jul 2, 2012
Is that based on actually analyzing the samples (converting both to e.g. 176.4/24 PCM format, and subtracting the Red Book version should result in no difference other than the higher quantization noise of the CD, and the ultrasonic content of the DSD), or do you just believe it is the case ? Do you even know if the playback levels are exactly the same ?
OK, guys, that does it. This post is CLEARLY meant to imply that anything above 44.1/16 is meaningless.
To all computer first/audio second guys (and gals, if any ) - converting, substracting, etc-ing is utter nonsense if you are at location and comparing various digital gizmos to the sound heard live - it IS audible that anything else than live feed from microphones is inferior to it and that magnitude of that deterioration is sample rate related .
I do try to match the levels - it IS exactly the same whether I use any setting for resolution from 44.1/16 as the lowest and DSD128 as the highest available on Korg recorders - and subjective results are as described by now countless times. Although I do not practice it on regular basis, sometimes I do match the level of recorder to direct output from the microphone - because that means I have to set the recording level a couple dBs below the optimum for the recording, as output level of recorder is fixed and to match the level with the microphone feed an additional preamplifier to raise the level of the mike would be required - or at least padding down the output of the recorder one way or another would be required. Both solutions add additional elements in the chain and none of these elements are perfect.
After doing it a couple of times - and hearing the difference(s) - I simply do not bother with it anymore - my goal is to make recordings best I possibly can, not to fiddle with ABXing and statistics and such. With differences as they are, one would not worry about the exact composition of tyres on cars being compared - if one is an average family car and another F1 car - would one ? It is true that getting from A to B in traffic congestion is no faster with F1 than family car, that F1 car is incomparably more costly, that it is a single seater, it can not carry any luggage, that it is utterly impractical for anything but racing, etc, etc - but if racing is the name of the game, it IS the answer.
I am striving to present these differences best I can - but if there is no virtual ABX comparator that can satisfy basic blind testing requirements AND quality of ALL format file playback ( it does OK for PCM ) - then it becomes hard. ANY non virtual real hardware ABX "box" with matching within 0.1 db or less with quality switching IS going to be expensive - I reckon 500 + for reasonable quality, but there are switches and potentiometers considerably exceeding that price - EACH. It is an area where commercial audio products have to make do with whatever can be used that fits within the selling price - you can't use $ 300 potentiometer in a $ 500 amplifier, for example. Take a "simple" RCA for example - there are $ .50 connectors ( sometimes I do use them, because they do sound good ) - and there are $ 200+ NextGen RCA connectors, with matching females at same level of price. NextGen will create better contact from new to who knows how many connection/disconnectio cycles - reliably, each and every time. .50 connector might work well initially - but will deteriorate with repeated use much faster and will fail completely after far less cycles than NextGen will still be good as new. The difference in price is approx 400 times ... - and I can only dream about NextGens.
Once in PCM, one can mix/remix/upsample/donsamle/whatever almost at libitum - and will remain "the same". Even back in the days I have been recording with CD recorder directly to CD, I did not care for dithering - as real world noises of both equipment and enviroment where music is being played are generally above the level dithering and more than 16 bits can improve upon in meaningful way. Not so with sampling frequency; one does get an incremental improvement, the most obviously audible one by doubling the sampling rate of redbook to 88.2 or 96 kHz. Above that, the differences are ever harder to hear and/or justify in financial terms - but that does not mean they do not exist and are not audible at least on top level equipment. That top level equipment in headphone world can cost less than 500 $/euro - to sky is the limit with speakers. That is to say that equipment capable of taking advantage of higher than 44.1/16 redbook sampling frequency recordings is not out of reach of majority potentially interested listeners.
I have to stress that the format or resolution of the recording is not in itself any guarantee of the overall quality of the recording. A Sony WMD-6(C) pro cassette recorder will produce infinitely superiour recording to any of the latest/greatest digital machines - if it is fed from better (positioned ) microphones than new digital gear. NEVER forget what comes first, resolution of digital is meaningful only if and when there is something worth supporting in the first place.
