It doesn’t really contradict the previous study, it just expands on it. The only thing it arguably contradicts is the “suggested benefits”, which were merely a suggestion anyway and based on correlation between certain mental/emotional states and certain brainwave types but of course correlation does not indicate causation. For example, a higher alpha wave power is associated with (results from) higher arousal but higher alpha wave power may not cause higher arousal.
Sure, it only investigated (and effectively eliminated) the filter ringing and >22kHz aspects of “hi-res”. The other aspect of “Hi-res” (16bit vs 24bit) was not investigated but has been by other studies and is somewhat easier because it’s a relatively simple question of physics/acoustics and noise floor levels/thresholds rather than frequencies which affect brain wave patterns.
Not sure I understand the question. If they were aware that they were “hearing hi-res over lower resolution” then they wouldn’t have been “blind(ed)”.
G
I think you and I are on the same page regarding Ultra High Frequencies(UHF) not appearing to effect EEG when listening to music.
Is that an accurate statement?
But you also admit, there is more to high resolution audio than simply UHF, correct?
high resolution audio also includes: improved quantization, which results in reduction of errors, reduced noise floor, reduction of artificial digital noise added to the signal as compared to 16 bit, etc. More samples give more points of time reference to the DAC, perhaps improving timing and filtering.
