bigshot
There are two kinds of cables. The right ones for the job, and the wrong ones for the job. A cable can't make anything sound any better. It can only make it sound worse. As long as you use the cable the component, be it DAC, speaker, headphone or IEM, was designed to be used with, you're fine.
Being disappointed with an aftermarket cable sounds like expectation bias to me. If it is the correct kind of cable, I bet all the difference would disappear with a proper comparison. Because...
You didn't level match.
You didn't directly a/b switch between them, opening the possibility of auditory memory skewing the results.
You didn't test blind to eliminate the effect of bias.
You didn't do multiple trials and average them to eliminate blind luck.
