I've had issues with Gregorio trying to speak from authority on issues I have more experience with (especially video standards).
Do you have any examples of where I tried to speak from authority about video standards? As far as I recall, I’ve never done so.
Went with Gregorio's thread of 16 bit audio while he also invoked how it relates to image quality. I have tried to provide real world examples of how he initially didn't understand dynamic range with imagery (he only understood 8-bit color space).
What I stated was: “
It's easy to see in a photograph the difference between a low bit depth image and one with a higher bit depth, so it's logical to suppose that higher bit depths in audio also means better quality.” - Which as far as the average consumer in 2009 was concerned, was a perfectly valid analogy. I wasn’t claiming or even implying any authority on image or video standards.
I do take him at face value that he is a sound engineer in Europe and has experience with multi-thousand dollar rigs.
I have some experience of multi-thousand dollar rigs but they were consumer rigs. At work, virtually all the experience I have is with multi-hundred thousand and multi-million dollar rigs.
Wow! I have hardly spent 1 % of that in the last 30 years, but then again I am the "bang for the buck" guy.
I’m a “bang for the buck guy” as well, the difference is that I need a different “bang”. A fair proportion of that €1m was on acoustic construction/treatment. Then there’s also mics, control surfaces/mixing desks, etc, and in the past, time-coded DAT and multi-track DAT machines. And, since I started nearly 30 years ago, I’ve had 3 studios.
So, you have spent more on cables alone than I have spent on audio gear in all!
Some of my cables are expensive. 50m of 24x3 or 16x3 multi-core is quite expensive and so are some of the special purpose cables.
Then again, I am not a millionaire, so I couldn't spent much more than I do.
I’m not a millionaire either. Although I’ve earned substantially more than €1m over the last 30 odd years.
In studio cabling I believe it is actually the high-quality connectors in the ends of the cables that cost the most rather than the cable in between.
Sometimes but not usually. As per commercial studios, I generally use Neutrik connectors which are about €4-5 each, although I probably use over 100 of them. Also, my studio has a machine room, so I have relatively few cables less than about 10 meters in length.
G
