dimapro
Hey guys! Do your buttons on the bottom (tranport controls) actually work? Mine don't repond at all. Nothing helps in the settings. Probably they forgot to connect the board on mine or would be fixed with the firmware update.
Hello. Could you share your feedback about difference in sound between v3 and v6?I have a V6 and it's fantastic. I have the V3 and it's really great. I think there was only one person or two that complained about Tempotec's service. I for one have had a few correspondences with them through their Aliexpress store and they have been responsive in a timely manner. The V6 has had a few updates to the operating system so far and works really well. The V3, can't seem to even check for an OTG firmware update as it seems to have an error when checking (probably is no update available yet). I actually hope that Hiby updates their app that both the V3 and Hiby R3II are using, as it's pretty sparse and unappealing looking. This version of the Hiby operating system, unfortunately, is possibly one of the least appealing versions I've seen from them. It's like Hiby made it worse for the less expensive players, which is not the way to go. Just give the good version, I say.
Yes, same problem. What's weird that the problem appears only in "Browse folders" view. When you actually play music it shows all tracks in the Queue. Like album has 2-3 songs but it becomes 10 when you start playing it.I try to browse music using files it only displays the first two tracks
Can you download the update?OTA update available now
Yes, I can download, but it doesn’t workCan you download the update?
It tried Doesn't like it's own download lo
the same errorSame message on my screen when updating
Please let me know on their feedbackSame for me too. I have emailed Tempotec and also queried with their AliExpress Official shop.
Same.It tried Doesn't like it's own download lol
Sorry, I meant can you download it to a card and install manually?Yes, I can download, but it doesn’t work
