JamesMcProgger
- Oct 8, 2010
Agreed, on the wood or aluminium change in sound. for me the mod its more about the look and the fact that I made it myself.
Additionally, one has to decide if they might like having the extra weight of the aluminum headphones on their head. I noticed my SR-325i to be a bit heaver than my woody SR-225. After extended listening periods, I like the lighter wooden cups for comfort a bit more.
Well, at stock, his RS2's kill my 225's. They have all the detail with much more warmth. I'm just thinking that wood cups are much better at handling resonant sound. I mean, they don't make pianos out of plastic...
Kojaku
tell me about it, I might need to use a neck support collar, the jaben aluminium cups are heavy.
Kojaku
^^^^^^^This.
I dint have superman ears and I dont consider myself an audiophile, but IMO this thread isnt 330 pages and counting just because people want to make their headphones look pretty. I'm guessing the guy that went Frankenstein on his HF2's wasnt doing it to understand the asthetics. I think resonant qualities of wood definitely impact the way the headphone sounds.and John Grado must think so too, from a Stereophile article talking about the RS1.
"The idea of using wood just came to me one night," explained John Grado. "We went through quite a few species of wood before finding this mahogany—which type, we'll just keep our secret for the moment. When you're building speakers, you're supposed to want a dense, really hard wood—well, that's not mahogany. But it works really well—I don't always spend a lot of time figuring out why something works; sometimes I'm just satisfied that it does. Maybe the mahogany has a lower resonant frequency, or maybe its resonance just doesn't emphasize something in my driver—I'm not saying it would work in all cases, but it seems to work well with our driver."
Different woods have different velocities of sound or internal dampening qualities depending on their density or how hard or soft they are. Hopefully some of the wood workers can chime in on this There is a lot more going on than just asthetics IMO.
That was me with the hf2s. The reason I took them apart was because they were in bad shape cosmetically. I destroyed the wood cups taking them apart. The replacement set of wood chambers was a different species of wood( i still don't even know what it is). From what I remember how the mahogany wood sounded, I cant really tell if the new wood sounds any different. Maybe it does though. They were gone to long to remember. I do know they sound good the way they are now. Long story short, I'm not sure if different types of wood make any difference in the sound. If it does, my ears cant tell the difference. Now from plastic to wood, sure you would tell a difference.
Who did your cups, wje? Cabillas?
Kojaku
Btw, has anyone here made a custom leather headband yet?I'm looking at leather to use for it and it comes us 1/2 sq. ft. increments. do I need more than that? Is .5 sq.ft. Not even wide enough to cut the headband out of?
Kojaku
I remember seeing the post where you had pictures of the disassembly... did you ever post "finished" pics of your HF2's?
