I have a few questions and thought some of you might know.
I did several mods on my SR-80 and like the results. The only problem is that I went too fast on the hole punch mod and did not like the results with 10 holes. I originally went with 4 I think, but somehow just went overkill. With 10 there is too much mid-bass on my pair. It's very bloated sounding.
I thought the best way to correct this is to use paper masking tape, but the sound has just not been the same. It's missing something.
I doubt anyone knows, but what purpose does the felt covering those holes have? Does it completely block out air or does air still get in?
Is there a better alternative to completely reversing this mod to just how it was before? It seems like when I used a thicker material it killed the highs, so I'm going to assume that felt still let in a bit of air? maybe I don't have a clue what I'm talking about!
I'm going to recable these next week. Has anyone tried Mogami with the SR-60 or 80? I love Mogami and it should be the best match. Based on my experience, Canare messes with the sound too much. Mogami seemed to offer the clearest sound without adding too much of anything. On the Canare I've experienced rolled off high frequencies slightly and too much bass.
One last question...
You know how some headphones have thin fabric paper covering holes around the driver? What is this? Does this also block out air completely or limit the air getting into the driver? What material can you buy that is the same thing? Masking tape?
Long ago I thought air could flow through masking tape slightly, but it doesn't. I didn't realize this until I tried a few experiements with other headphones,
BTW I'm still using my Koss Pro DJ 100 headband with my SR-80. I love that combination, but for larger heads it's much too small. I still believe the DJ100 comes from the same manufacturer as the Grado drivers. Same size and everything. DJ100 driver can even fit in the SR-80 shell.
Today I think I might do some modding with Akasa foam and see if I notice any changes. I have some spare Canare wire around, but I might just wait until my Mogami arrives.
