I know it sounds funny to say white ebony...
SR60-Mod
- Thread starter Bilavideo
sharkz
Very Zebrawood-like. That was my only disappointment, the lumber yard I visited was out of Zebrawood. Some guy had claimed it all for a very good looking bar surface.
It almost looks like those tasty black and white swirled brownies.....
yomomma1
- Nov 18, 2010
White ebony isnt that an oxymoron
May be, but it sure is some good sh!t
Well, it looks really sweet, but it is hard to mill well - it "checks" when you mill it down to 3/8 thickness or so, I had to make 3 cups to get 2... I will sand them and dremel the cable spot another day, I am tired of this stuff for now. It does have a nice vanilla and chocolate swirl thing going on though, I will try them out and see how they sound vs East Indian Rosewood.
sharkz
I feel your pain. I had to make three Padauk cups to get two, although my third is still good. Better than the day before when I made five and could use none. Even the Purpleheart, I made two and am not sure one will be usable due to some cracking. I guess such is the nature of the work.
Bilavideo
Caution: Incomplete trades.
- Feb 29, 2008
[size=small]Hello gang, emboldened by Bilavideos recent basket mod I chose to follow suite. However instead of drilling additional holes in the basket as Bill did, I chose to simply enlarge the existing holes (from the stock .116” diameter to .193” by “hand” drilling using successively larger drill bits). [/size]
[size=small] [/size]
Before mod:
[size=small][/size]
After Mod:
[size=small][/size]
Well, aren't you a clever son of a !@#!#!!!
Nice job, Big Bill. I'll bet they sound awesome! Tell me if they do, because if they do, WE'VE GOT ANOTHER MOD!!!!!!!
Duckman
- Nov 14, 2008
Big Bill,
What is the effect of such large holes?
I'm wondering how many holes to make when I get an SR60, but want to avoid any 'bass monster' effect.
Cheers,
Dave
Cheers,
Dave
I found that 4 holes in each side made a nice difference, 6 holes was perfect with the bowl pads, and 10 holes can be a little loose, but I am hoping it is perfect for the bagel pads, if they ever show up. I would start with 4 per side, then reassemble with tape or blu tack, and test. Using the stock comfies, 4 holes is very nice.
Big Bill
- Jan 16, 2011
Thank you sir! I'd have gone wider, however the blades of the drill bit were all but scraping the Mylar at the drivers edge @ .193" diameter. They do indeed sound amazing post mod and I believe this mod is a must for any one who has fully liberated their drivers. My thinking here is that once the forward resistance supplied by the factory grill/wave guide is removed, the balance of resistance between front/rear of the diagram becomes skewed and needs "adjusting".
redrum42
- Dec 28, 2008
After venting 2 holes I seem to be noticing some boominess on certain bass frequencies. Sounds like the cup is resonating. Have you guys noticed this? I can't compare to how they used to sound, but I never noticed a trace of boominess before with my grados...
sharkz
Well, I wrecked a driver. I don't know how it happened. I was careful during my recable and have checked all my connections twice and my right driver is dead. I am so freaking mad right now. I wish I knew what I did wrong.
hi-fiber
- Jan 4, 2011
thats why grado does not vent drivers on plastic housings... put felt around it to suppress the boom. you might experience some crowdiness afterwards.
Danthrax
- Dec 28, 2010
Did you wire it wrong?
sharkz
No, must have melted/broke something. No idea how, I was very careful with low heat and everything. I have soldered and unsoldered the other driver like 5x now with issues with it. I am really annoyed though.
If anyone has an extra driver to spare, please PM me. I am interested in getting another as soon as possible!
Bilavideo
- Feb 29, 2008
It has taken me three readings to get to what you are saying. On my first two readings, I thought you were telling him what a fool he was to vent the drivers. Instead, as I now see it, you are saying what I am saying, that Grado uses the felt to suppress the boominess that would occur with plastic housings. The real culprit here is the plastic housing. Plastic sucks. Change to wood or aluminum and life gets better.
Total: 8 (members: 0, guests: 8)
