Carlosfandango
- Jan 11, 2010
Baka, I think they were a pair of Strato's phones.
Maybe check his profile.
+1 to the unplugged nirvana and Alice in Chains albums. Both are great. I'll check out those sounds you posted shortly Kneel. I always like getting schooled on music.
If other fellow head-fiers are interested in the manufacturing process of this pair of headphones, I'll be pleased to post a translation of the original thread that I started at the spanish forum (though I believe that the pictures themselves are quite self explanatory). I’ll be happy if some of you find anything of what I’ve done useful.
By the way.... learning Spanish can also be considered a DIY project, markkr.
http://cdn.head-fi.org/5/56/5614377b_coco4.jpg
These?
Stratocaster owns them.
Although Strat's is great looking that's not the ones I was thinking of. The ones I'm thinking of goes back a couple of years ago. I even tried to Google it with no luck. It was definitely on Head-Fi though.
So I'm thinking of removing the button, and then maybe go on to remove the grill at a later date.
First time I'm ever modding a headphone so... help me out here
I'm not even planning to remove the clip that holds the cups together since it's a fairly
simple mod.. To be honest, I'm afraid to even take the clip off the cups, they look too
fragile.
So..
Steps
1. Place the headphones over steam for a couple of minutes.
2. Pull the button off with my fingers.
3. Done.
Do I need to take everything else apart and superglue them back together or do I just remove the button
and let the headphones cool?
And what about the steam condensing on to the headphones? Won't that destroy the drivers or wires or something?
