71 dB
So nothing should be better than required?Good enough is good enough?Thats gonna kill a lot of hobbies bud.
Nothing is better than required in every area. It's about putting effort on things that matter.
right...but if you improve things that matter and your system cant show improvement because you drew a line at good enough?Nothing is better than required in every area. It's about putting effort on things that matter.
a deviation from what? do you assume your playback system is flat and your TV ideally calibrated without doing anything to them?
agreed...i think lolThen the line of "good enough" is clearly wrong. Good enough should mean improvement don't matter.
Yep definitely need some fresh thinking in the industry. ....much as i like a nicely polished turd.I think that fresh thinking needs to be in the analog domain(if i am to believe what i read in sound science)differences are most likely in the analog part of our hobby?I don't think "good enough" is the issue. we probably all have a different "good enough" for most things by ability or desire. the matter in audio is often that people are delusional about what to expect. they will look with a magnifying glass at a tiny portion of the recording or playback chain, while missing how that tiny stuff they want to preserve to the nᵗʰ level was squashed before it came there, and will be squashed again before it reaches the brain or even the eardrum. yes every part of the chain participates in the final level of fidelity. but it's just as true that the final level of fidelity will still be limited by the worst element in the chain. losing sight of this is the only reason why we have all that false hifi hobby where we are told to run after meaningless but easily marketable variables. and in the meantime, almost nobody stops to wonder why a headphone, by far the weakest link in fidelity, is also the only one usually sold with no data relevant to fidelity.
deciding if noticeable is enough, that's up to the user IMO. but it would really be good for everybody if those obsessed about fidelity were driving the industry toward ... well, fidelity instead of new ideas to better polish a turd.
100% agree....didnt see that one coming. .you keep surprising me my friend. ...not a very scientific comment lol.Of course i expect graphs with spikey lines ectI hear stuff today that is better than anything I've ever heard. I don't think technology is the problem when it isn't good. Lack of passion is usually the problem when something sucks.
Those Magnepan flat speakers are supposed to have very low distortion levels at reasonable listening levels- down around .2% give or take a bit. I would call that inaudible. But you'd need a sub for bass, and I don't think you could do that with the same kind of accuracy.
I guess it depends on what you define as zero audible distortion. The ear is less sensitive to distortion in some frequency ranges than others. And distortion can be defined as any deviation from the original signal, so room acoustics would have a huge impact on it too. If you're just talking for the purposes of listening to music in the home, I'm sure you can get close enough that it wouldn't matter. The law of diminishing returns would be in full force though.
Even if you had zero distortion, it doesn't mean that your music would sound exactly like a live musician in your living room, because music isn't mixed for realism. It's mixed for a balance and perspective that is better than realism.
