aisalen
- Mar 17, 2017
The Z7 is very close to the Z1R. Sound wise build wise and comfort wise. If you don't know the Z1R, the Z7 is all you ever need. Then later out of curiosity you might want to check on the Z1R too. For the Z7 you only need to get the correct balanced cables to connect to the WM1A and the Jotunheim. Again, the Z7 is already epic to me.
The Z1R is built for a bigger sound, more details and more spacious, but is close to the Z7 in characteristics. So maybe in many songs they do not distinguish, and the Z7 could be smoother because it doesn't have that metal dome.
Thanks for the answers, good to hear that their sq are similar in some way. I heard Z1R in a demo from the Sony store with the noisy environment and I like the sounds coming from it, totally different level that is why I am wondering about the Z7 if the same at least.
