- Jul 7, 2014
wow you guys have been busy on this thread while I was away... Trying to play catch up and saw these 2 posts...
You both have me real curious about this now ha. I miss the RH-5 being down here since Mark brought it upstairs . I think I am going to go steal it now.
I have heard it with a mix of headphones, but I don't remember any listening to it with the Z1R. We currently have the Rogue RH-5 sitting upstairs in Northern Audio which is all 2 channel equipment and speakers. We use the RH-5 as a pre amp, and its possible to get a phono board put in to use as a phono pre amp as well. When I get a chance ill go up there to see about synergy with the Z1R!I'm wondering if a headphone amp will provide any real advantage for the Z1R over my Mytek Brooklyn's headphone section. In particular I'd like views on the Rogue Audio RH-5 if anyone has heard it, since it offers a good range of connections including four-pin balanced which I'd want, and a remote. I'm also thinking of Violectric V280. But no point in throwing down money without significant improvement in SQ. Thanks.
I don't see any necessity to run the RH-5 balanced output since like you said the Z1R is pretty easy to drive... The RH-5 is a very neutral sounding amp for a tube amp, so with that said it wont have that "syrupy" sound that some tube amps have. Now tube rolling the RH-5 would be a different story... I really like the amp because of how powerful and clean it is. I think its for someone who has multiple headphones of different power needs, and or someone wanting a higher end all in one.Z1R is a really easy load to drive for any amp. Not sure what a 4 pin balanced connector would do for you unless your hp cables are covered in power cords or you are running a 200' run of hp cable. I think any other SS amps would render very subtle changes. Tubes on the other hand is an entirely different discussion. Some guys say no tubes with the Z1R. That Rogue amp does look interesting.
